D16 ZC DOHC CRX need parts
I'm lookin for name brand upgrages for my 3rd gen D16zc dohc. I've been lurking and have found the names vitara for pistons. What parts do you have on your cars? I have 2 engines ones going turbo I'm lookin for pretty much everything except the block and head.
Re: D16 ZC DOHC CRX need parts
Vitara pistons on DOHC ZC engines lows the static CR near to 6.5:1.
I'm running 15 PSI from a Garrett GT2860 on a DOHC ZC engine, using Eagle rods and PM6 pistons, static CR is around 8.4:1 with 0.050" Cometic MLS gasket. You can use PG6 pistons, them would give you a static CR of 9.0:1 (using 0.050" gasket). Engine develops around 280HP at crank and 260HP at wheels, on stock cams and head.
hondaless
06-30-2002 12:04 PM
