d16 map sensor on b16?
Old Apr 30, 2003 | 08:35 PM
pissedoffsol's Avatar
25 Year Member
Default d16 map sensor on b16?
will it work? any voltage differences?
Old Apr 30, 2003 | 08:42 PM
RCautoworks's Avatar
Default Re: d16 map sensor on b16? (delvtecsol)
Yes it will work. If both map sensors are located in the same spot, such as if your old car has it on the fire wall and your new b16 don't have it on your throttle body, you will be fine. If there different, then you might have a little problem.
Cian Mcloughlin
May 20, 2013 10:11 AM
jw15u
Nov 14, 2009 06:57 PM
kechup2eg6
Aug 10, 2005 07:47 PM
sirminder
Jun 18, 2002 04:52 AM
