D16 -> D18
Old Sep 16, 2001 | 01:12 PM
D16coupe's Avatar
New User
Default D16 -> D18
Is the only way to up the displacement on a D16Y8 to bore out the cylinders, or is there a crank that can be swapped in? Does anyone know of a machine shop in FL that perform the bore?
Old Sep 16, 2001 | 02:33 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: D16 -> D18 (D16coupe)
To go to a 1.8l you'll need to sleeve the block. I don't think the factory sleeves will withstand that much material coming out of it.
Your engine is Bore 75mm x Stroke 90mm = 1590.38cc
You need to get a 1.8l you would need to go with 80mm pistons, which would give you a 1809.50cc engine.
So this means you need to bore the block 5mm total. I don't think you'll have much of a factory sleeve left when your done.
Sorry.
Old Sep 16, 2001 | 05:34 PM
maxim's Avatar
Default Re: D16 -> D18 (B18C-EJ1)
why go against the grain when you can just do what everyone else does in your situation and just swap with a B18c.
Old Sep 17, 2001 | 07:43 AM
sohc_boy's Avatar
r & d racing makes a stroker kit for the sohc 1.6, they were in a recent past issue of scc forget which one the article was about all motor honda drag engines. the sohc they did the article on made 215 hp at the wheels
[Modified by sohc_boy, 11:43 AM 9/17/2001]
Old Sep 17, 2001 | 02:48 PM
D16coupe's Avatar
New User
Default Re: D16 -> D18 (maxim_force)
Why go against the grain? Mainly for just that reason, I think I could turn alot of heads with a 300+ hp sohc. I know I can sleeve and bore it, I was really hoping someone knew a little trick for stroking, perhaps a b18 crank... (like an H22 crank in a B18 which yields just over 2L)
Old Sep 17, 2001 | 05:28 PM
redsin95's Avatar
New User
do you happen to have a website or contact information for r & d racing. that stroker kit is kindof interesting to me. thanks for the info.
Old Sep 18, 2001 | 05:03 AM
sohc_boy's Avatar
Default Re: D16 -> D18 (redsin95)
its posted at the end of that article in scc i will try and see if i can find the number for u.
Old Sep 18, 2001 | 05:10 AM
sohc_boy's Avatar
it was in the august issue of scc the articles name was all motor madness anyone have the mag still if so can u get the number for the guys who built l'natural and bizi's motor i think it was r & d not sure on that? i will chk when i get home if no one posts it.
Old Sep 18, 2001 | 10:36 AM
D16coupe's Avatar
New User
I'm in love. They brought a D16 to 2000cc. D20. There is no website listed in scc but the phone number is (310) 516-1003
Old Sep 18, 2001 | 02:35 PM
redsin95's Avatar
New User
i just called. they have a stroker kit that will apply to a 1.7, 1.8, 1.9 or a 2 leter motor. they have street and strip application, and also a boost application for all stroker kits, the 1.8 leter street kit is roughly 2200 i think not shure on that though. it comes with wrings, wristpins, crank, rods, pistons, they use je or another brand of pistons i forget. they upgrade the rods for boost applications.
they will have a website sometime in the next month to display what they have. they seam to know what theyare talking about and was quick to answer any qestions that i had. i wanna do it.
Old Sep 19, 2001 | 04:27 AM
sohc_boy's Avatar
go d-series
Old Sep 20, 2001 | 11:22 PM
SpeedCon Turbo ZC 619's Avatar
New User
i like going agianst the grain ( b-series motors) with my turbo zc. i could have spent the same amount of money for a gsr swap and with all the bolts ons, port work, upgraded valve train and ecu, vtec controller etc.. and still not be as fast or as fun as my turbo zc.
yeah that R & D 2.0L D series motor was Bisi's.
Old Sep 21, 2001 | 02:44 PM
MrDX's Avatar
Default Re: D16 -> D18 (SpeedCon Turbo ZC 619)
The name of the shop is R&D Dyno out of Carson, CA. That's the info I got from that number.... I'd go for a 2L SOHC anyday. They have a web spot set aside at
http://www.customcreations.com/R&D.html
[Modified by MrDX, 6:46 PM 9/21/2001]
everyonesnaturalenemy
May 24, 2007 05:03 AM
turboman
Jan 12, 2006 09:33 AM
Negative3Five
Sep 3, 2004 03:16 PM
NLR808
Aug 3, 2004 10:17 AM
smp534
Oct 25, 2001 10:54 AM
