D15b7 problem
Old Mar 18, 2017 | 11:45 PM
CHodgeb18's Avatar
Default D15b7 problem
I have a 94 eg coupe. I have replaced main relay, spark plugs and wires, and fuel pump. When I crank my car its perfectly fine until it starts warming up. Then the car starts hesitating then just cuts off. After it cuts off the fuel pump and fuel injectors keep cutting off and on( like 4 or 5 times) then stops for a second or two then does it again and so on. Does anyone have any idea why??? Thanks for any help/advice
Old Mar 19, 2017 | 09:06 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: D15b7 problem
If the ECU gets intermittent signal from the distributor it will effect injector pulse.
The first thing I would do is clean your grounds. In particular, ground G101.
It is the ground on your thermostat housing on the engine.
After that I would begin investigating the distributor by doing the ICM and coil tests.
Old Mar 19, 2017 | 11:28 AM
CHodgeb18's Avatar
Stupid question but where is G101? In the ECU?
Old Mar 19, 2017 | 11:32 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Old Mar 19, 2017 | 01:47 PM
CHodgeb18's Avatar
Thanks man. Will check it out as soon as I get back
91civicwa
Nov 5, 2012 10:07 AM
civiczccoupe
Mar 28, 2012 06:05 AM
lott101
Jun 25, 2011 08:53 AM
X-MOB03
Oct 20, 2004 06:38 AM
JolToN49
Nov 20, 2002 11:41 AM
