D15B VTEC pressure switch...
Old Mar 23, 2005 | 11:17 AM
Exempt's Avatar
Default D15B VTEC pressure switch...
I did some searching, and found out that some JDM engines didnt come with a VTEC pressure switch, and that it was controlled from the ECU... Well I think my engine is one that dosnt have one... I am using the P28 ECU, which will search for one... I know I can do the jumper wire from D6 to A4 or whatever it is, but I would prefer too add a switch for safe measures...
Heres a pic of my VTEC silenoid:
So my question is, can I take out that bolt the arrow is point too, and add a VTEC pressure switch? Is that what thats for? Or do I have to buy a different silenoid with a switch?
Thanks in advance!
Old Mar 23, 2005 | 05:33 PM
cyph3r's Avatar
Default Re: D15B VTEC pressure switch... (Exempt)
take the bolt out. throw a shitch in. your lucky some didnt even come with the bolt, was just blocked off and you had to replace the whole vtec assy.
Old Mar 24, 2005 | 03:15 PM
dnoredsi's Avatar
THEY ALL COME THAT WAY. FROM FACTORY 92-96
Old Mar 24, 2005 | 03:34 PM
Exempt's Avatar
So, to add a switch, I just remove that bolt and screw in the sensor?
Old Apr 2, 2005 | 08:22 PM
dnoredsi's Avatar
Default Re: (Exempt)
take the vtec oil pressure sensor from your old vtec solenoid, unscrew that bolt and put the sensor in its place. then put that bolt in your old head so it doesn't leak.
check the sig i think theres a clear pic of it done on mine.
monkeymk2
Feb 26, 2019 10:49 PM
Freya Franco
Engine Management and Tuning
Dec 13, 2017 10:49 PM
Tunerguy1989
May 5, 2009 02:54 PM
