D15B Engine swap does not start
Old Feb 7, 2016 | 08:26 AM
komet 163's Avatar
Default D15B Engine swap does not start
Hi all.....first of all excuse my English, I use translator
I'm doing a swap to my honda is a D15b OBD2A .... I have the engine installed with the connections made ... but when I do start. turns but does not start ..
I check the spark plugs and have fire
I also check the fuel pump and fuel going to the engine
when I give ignition, a couple of times. spark plugs get a little wet fuel
I must say that it lacks two sensors one is IAT and the other is a kind of solenoid is connected to the EGR... I also need to connect the radiator. can any of this be the problem.
Old Feb 9, 2016 | 06:38 PM
komet 163's Avatar
Default Re: D15B Engine swap does not start
nobody???
Old Feb 10, 2016 | 01:12 PM
jwest1150's Avatar
what car? This might be best for a model specific forum. 92-00 civic/del sol?
Old Feb 22, 2016 | 08:39 PM
komet 163's Avatar
honda crx 1gen
Old Feb 24, 2016 | 03:44 PM
motoxxxman's Avatar
iat sensor is necessary. it can not run correctly without it.
it probably has a wiring issue somewhere
Old Feb 28, 2016 | 06:29 PM
komet 163's Avatar
I understand that the iat sensor is needed to run the car, but I want to know if I can give starting without the iat sensor, only starting without moving the car.
Old Mar 13, 2016 | 09:35 AM
komet 163's Avatar
nobody???
Old Mar 15, 2016 | 09:40 AM
komet 163's Avatar
Old Mar 15, 2016 | 10:46 AM
2point1's Avatar
What Ecu,distributor are you using?
Old Mar 15, 2016 | 06:00 PM
komet 163's Avatar
ecu is P2J-J62.... Aand the distributor is a OBD2A stock.... My engine is a D15Z7 called 3 stage vtec
Old Mar 15, 2016 | 06:38 PM
2point1's Avatar
Is the timing set right?
Is the crank sensor plug plugged in?
Is the valve lash set right?
Old Mar 16, 2016 | 05:57 PM
motoxxxman's Avatar
yes. but only if everything else is perfect. and even then, it will be tough to start, and will run rich and not very good.
These are good questions, I would answer these so we can help you more
Preludeman1
May 28, 2013 08:49 AM
tambara
16
Apr 20, 2008 01:01 PM
fonpee
Jul 3, 2007 05:49 AM
quad
20
Mar 14, 2007 05:16 AM
roxy2000
11
Aug 16, 2005 12:34 PM
