cyp (cylinder postion code)
From: gravity rides everything...everything will fall, se GA/ne FL
i have this code and also one for fuel injectors. what should i be checking? isn't that sensor in the distributor? also for these two codes the car won't rev past 3200. this is all happening on a b16 with maxrev turbo kit...put in 450cc injectors and the hondata base map chip. i even tried to run a stock ls ecu and stock injectors and it still hits the 3200 rev limit so i am thinking it has to do with the cyp sensor and not the injectors besides they are brand new. thanks
-kevin.
-kevin.
HondacivDX
Jan 22, 2011 09:12 AM
