1998 civic b16a2 throwing p1382 code
tried searching anything on this and cannot find nothing...well anyway its a 1998 civic dx with a b16a2 i recently threw 320cc high impedence injectors and it threw a p1382 cyp sensor circuit 1 was wondering if me putting in those injector would cause this code or not help needed thanks
The Grumpiest
Re: 1998 civic b16a2 throwing p1382 code
Why did up upgrade injectors? Is the car boosted? Did you retune it for the new injectors? Does the CEL go away with the stock injectors? Did you reset the ECU? That sensor is in the distributor. I don't where YOU were searching but everything I'VE researched says that you can replace the sensor http://www.google.com/search?q=civic...1062ed1d424d73 or replace the distributor.
yea i was gonna tune it for bigger injectors but i put the stock ones back in and still the same code. i cleared it out and it comes right back....i pulled off my cap and rotor and found out that the rotor screw came out and fell back in the distributor...took it out i replaced the screw and cleaned the in side out with electric parts cleaner and the code still comes back...seems like i need a new dizzy...???
