ctr pistons jdm gsr, fuel setup ?
Old Feb 15, 2005 | 09:58 AM
blueskiesfade609's Avatar
Default ctr pistons jdm gsr, fuel setup ?
ive been looking in the forums, ive searched. i see alot about how ctr pistons up your compression to around 12-1, how you need fuel upgrades, higher octane gas, and have your car tuned. my question is, what fuel upgrades(pump? injectors? fpr?) and how do i go about tunning, should i just look into hondata or actually take it to get tuned and dynoed? if i do that how exactly does that work.
Old Feb 15, 2005 | 05:37 PM
T4eg's Avatar
Default Re: ctr pistons jdm gsr, fuel setup ? (blueskiesfade609)
ur stock fuel setup should be fine. I ran almost the same setup. gsr, ls crank and rods, ctr pistons, gsr head, I ran stock gsr fuel pump and injectors with a inlinePRO fuel rail (just cus i had it laying around). I would get a fuel pressure regualtor and look into hondata then get to the dyno
Chris
Old Feb 15, 2005 | 06:15 PM
mmuller's Avatar
Mad Scientist
ctr's will yield a lot more compression than 12.1 more like 13.some...
read the 1st post on the all motor forum...
tuning is a must, specially if you live in hot climate.
Old Mar 10, 2005 | 05:56 PM
GSR_YEAGER's Avatar
Default Re: ctr pistons jdm gsr, fuel setup ? (BlueHatch00)
"ur stock fuel setup should be fine. I ran almost the same setup. gsr, ls crank and rods, ctr pistons, gsr head, I ran stock gsr fuel pump and injectors with a inlinePRO fuel rail (just cus i had it laying around). I would get a fuel pressure regualtor and look into hondata then get to the dyno"
what kind of numbers could you see w/this set up?
rex_racer728
Aug 25, 2005 06:53 AM
92slowvic
Aug 20, 2004 05:41 AM
phantom_sol
Jan 22, 2004 11:50 PM
gsr2jdm
Oct 4, 2003 08:14 AM
Trajic
Oct 3, 2001 12:37 PM
