CTR Pistons in 92gsr?
Old Dec 18, 2002 | 07:28 PM
Skunk2_92gsr's Avatar
Default CTR Pistons in 92gsr?
Im thinking about getting some CTR pistons in my 92GSR B17a1.. do the pistons fit right in? any modifying have to be done? also do you think id be better off buying a set of skunk2 stage 2 cams w/ dual springs and titanuim retainers? or would i be better off just getting a ctr intake cam? any kind of advice would be great im trying to shoot for arround 200 hp to the ground all motor. Thanks!
Old Dec 18, 2002 | 07:31 PM
dohcsideSi's Avatar
Default Re: CTR Pistons in 92gsr? (Skunk2_92gsr)
not going to make 200whp with stock bore ctr's or skunk stage 2's....
i would work the head first...skunk 2's are very nice can't go wrong there
Old Dec 18, 2002 | 07:46 PM
Colin's Avatar
the ctr pistons are great for the b17a, they will give you 11.36:1. They will require some mods however. You have to shave your rods approx 1mm on each side. This is a simple mod and any machine shop can do it. It won't hurt the strength of the rods either, so don't worry about that.
like the other guy said, you're not going to make 200whp with the ctr pistons, you won't even get 200whp with ctr pistons AND the skunk2 cams. Its gonna take quite a lot to get your b17a to 200whp. But the ctr pistons are a good start. Get those, some good cams (skunk2 stage 2 would be a minimum i'd say), headwork, good intake, itr intake manifold, good header, and good exhaust and some more mods.....and of course tuning.
Old Dec 18, 2002 | 07:54 PM
Default Re: CTR Pistons in 92gsr? (91IntegGS)
How hard would you say it is to put them in? so other than the fact of shaving the rods 1mm on each side, is it just a drop in modification? ive decided on the Skunk2 stage 2 cams, Titanuim retainers and dual springs... and this may be a dumb question but is it safe to take the shaved rods up to 9,000 rpm? Thanks.
futureracecar
Feb 26, 2010 11:37 AM
albciivic
Apr 3, 2008 12:50 AM
xonefastackx
Apr 24, 2005 02:39 PM
qbsi
Jul 19, 2002 07:43 AM
