CTR pistons in 1st B16A????
Old Aug 19, 2002 | 01:28 AM
EG3-R's Avatar
Default CTR pistons in 1st B16A????
im planning to put CTR pistons in my 1st gen B16A, juss wondering if this set up is safe for my motor. if i do put them in wat grade of gas should i use??? 100 octane??? will there be any valve-pistons problems???
i need all da help from u guys....so if anyone have tried this set up b4 pls let me know!!!!!
THANKS!!!!
Old Aug 19, 2002 | 06:38 AM
CHEETAH's Avatar
Default Re: CTR pistons in 1st B16A???? (TYPE-ONE)
I use it right now with head milled 20 thous and run 93 Hess fuel... no ping.
Greg
Old Aug 19, 2002 | 06:49 AM
p-boy's Avatar
Default Re: CTR pistons in 1st B16A???? (CHEETAH)
ive got a milled 40thousands on my head.. and ctr slugs using 97 octane petrol no pings watsoever.. when i go lower than 97 i can hear ping on accelration...good luck dude!
Old Aug 19, 2002 | 04:27 PM
88crxoncrack's Avatar
Default Re: CTR pistons in 1st B16A???? (p-boy)
i had them in my ooooold b16. no problems on 92+ octane. head was milled minimally. no pings, had remapped ecu with nasty fuel curve though.
Old Aug 20, 2002 | 07:05 PM
MisterB's Avatar
Default Re: CTR pistons in 1st B16A???? (88crxoncrack)
would i have any problems running os ctr pistons in a b16 on 91 octane?
thanks
Old Aug 20, 2002 | 07:59 PM
Default Re: CTR pistons in 1st B16A???? (cl4show)
no, the lack of displacement in a B16 makes it fairly safe. The CR is much higher in 1.8's and plenty of people are using that setup with relative ease.
Old Aug 20, 2002 | 09:02 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
just to be more accurate, it is not the displacement per say, it is the relatively small bore that allows for high CR on B series. and very good chamber design.
stan
Old Aug 21, 2002 | 03:24 AM
EG3-R's Avatar
Default Re: CTR pistons in 1st B16A???? (90crxsi)
so its all good....it should be fine...pump gas here in australia is 98 octane. ill be runnin it with juss da normal b16 head with SPOON thin head gasket and ITR cams.
thanks guys!!!!
Old Aug 21, 2002 | 05:31 AM
Ruby Civic's Avatar
not a problem whatsoever....good choice, but don't forget the milling on rod end so you will fit (about 1 mm total taken off width) piston.
Old Aug 22, 2002 | 02:49 AM
EG3-R's Avatar
Default Re: CTR pistons in 1st B16A???? (Ruby Civic)
isnt 1mm both side of da rod end????
Old Aug 22, 2002 | 05:57 AM
WAFFLES's Avatar
Yes just one millimeter off both sides. But I will say that if you are planning on running a Spoon 2 layer head gasket you might want to reconsider. A lot of people have been blowing them, the Mugen piece seems to work a little better. Either way good luck man...sounds like you have a really nice setup on the way.
Old Aug 22, 2002 | 07:14 AM
Katman's Avatar
yes, here's a diagram to help you understand what needs to get milled:
Old Aug 23, 2002 | 07:04 AM
EG3-R's Avatar
Default Re: CTR pistons in 1st B16A???? (Katman)
thanks dude!!!! i hope everthing will work fine.....i should be ordering my CTR pistons in new zealand pretty soon......
Old Aug 23, 2002 | 08:31 AM
p-boy's Avatar
HEY CHIE how much are those slugs gona cost u over there?
Old Aug 23, 2002 | 11:54 PM
EG3-R's Avatar
560 new zealand dollars...dats around 500 australian....and dats about 12500 philippine pesos!!!! is dat cheap???? its brand new from HONDA NZ.
Old Aug 24, 2002 | 06:20 AM
that's about 260 US, that's a grip, unless that's with rings.
Old Aug 24, 2002 | 06:30 AM
Katman, completely OT, but i have to ask, due to the fact that i anticipate the reopening of your site for a while, i trace back the pictures you post to their respective parent directories . the questions is, how the hell do you keep your engines so damn clean?!
stan
Old Aug 24, 2002 | 07:14 AM
EG3-R's Avatar
everthin is included, pins and rings!!!!
Old Aug 24, 2002 | 11:38 AM
p-boy's Avatar
thats heheh thats way to cheap even compared here dude hahahah here it goes for 16000php... good luck mang! anyway.. im building a crvtec..watche think chie?
Old Aug 31, 2002 | 10:20 AM
Katman's Avatar
stan
i guess the pics are decieving for some of our engine bay pics. Just wipe it down with a rag & cleaner...that's about it.
Old Jun 25, 2003 | 06:16 PM
wm5holla's Avatar
thanxs guys
hott95ej2
Sep 15, 2009 07:32 AM
chocolatecivic
Jun 23, 2006 06:23 PM
1stealthls
14
Apr 24, 2005 10:37 PM
DarkSubRosa
Feb 28, 2002 03:57 PM
