crvtec finished, still have 1 last problem... please help
Old Feb 21, 2003 | 09:30 PM
irev210's Avatar
Default crvtec finished, still have 1 last problem... please help
Okay, i finished my crvtec swap into my 89 CRX HF, I got blown90hatch's obd0-obd1 harness, so im running obd1, i had a problem with a bad injector resistor box, so i just went with obd1 saturated injectors... so today was the first day i was really able to drive the car. I notice that once the engine warmed up, a loud screech came from the engine. I dont know what it is. When i give the car gas, the sound goes away, once i left off the gas, it comes back. Its fairly loud, and im afraid to drive the car because I dont want a main bearing going out on me or something.
If anyone can help, Id really appreciate.
Old Feb 21, 2003 | 11:33 PM
irev210's Avatar
Default Re: crvtec finished, still have 1 last problem... please help (irev210)
okay here is an update
took off A/C belt
took off alt belt
took off upper plastic cover
pressed in clutch
when the engine is turned off, i can see the timing belt stop, but for a second after the belt stops, the stupid whine is still there... its comming from the motor, the whine stops about a second or 2 after the motor STOPS moving
im very confused
someone please help!
Sorry if it doesnt make much sense, but im very tired
Old Feb 22, 2003 | 06:26 AM
PhatOptimo's Avatar
Did you bash the frame rail to make room for the alternator pully? Alot of times the alt pully will rub the frame rail and make a super loud screeching noise. A smaller alt belt may help if this is the problem.
Old Feb 22, 2003 | 11:19 AM
dfoxengr's Avatar
Default Re: crvtec finished, still have 1 last problem... please help (Phat_Optimo)
he said he took of the alt pulley and the problem is coming "from the engine"....
check tension of timing belt
Old Feb 22, 2003 | 11:32 AM
irev210's Avatar
Default Re: crvtec finished, still have 1 last problem... please help (hybridvteceg)
turns out it was a hose hooked up to the wrong place
crvtec owns me now
***** alot faster then i thought it would be
jason20009
Acura TL, RL & ZDX
May 16, 2009 10:06 PM
froogle29
Dec 12, 2007 04:32 PM
hondacrxflyer
Dec 3, 2004 07:29 AM
irev210
Feb 26, 2003 01:42 PM
