CRV throttlebody???????
will this bolt up to a skunk2 intake manifold for a 94 b18c1 head and will it have all the sensors i need? also does anyone know the diameter of the crv tb? is it bigger than a gsr?
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20_EK »</TD></TR><TR><TD CLASS="quote">nope the same. I think its 60 mm, or 62 mm. not sure. But I know they are the same</TD></TR></TABLE>
so they are the same diameter. do you know if it will bolt on and have all the same sensors as a gsr tb?
58mm
58mm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT »</TD></TR><TR><TD CLASS="quote">
58mm</TD></TR></TABLE>
im pretty sure its 60mm, my ls is 60mm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT »</TD></TR><TR><TD CLASS="quote">ls is 58mm
i measure the original throttle plate on my 95 LS T/B after i had it bored to 64mm. with my handy digital micrometer it measured out to 60mm......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller »</TD></TR><TR><TD CLASS="quote">where the throttle cable hooks into, before the throttle bracket</TD></TR></TABLE>
do you guys mean the tb pulley that turns with the butterfly when you step on the gas????????? sorry guys i'm not sure what your talking about? i have a b18c1 in a 92 si hb. does anyone have any pics of what you guys say i will need. thanks
Some are 58mm.Moslty the older ls tb's i have seen are 58mm.Most of the new ones i have seen are 60mm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT »</TD></TR><TR><TD CLASS="quote">I have yet to see one measure 60mm. i have 3 00 GSR, 4 94-00 LS, 4 b16a and 2 H22A and they all are 58mm.</TD></TR></TABLE>
hey man do you know if the crv tb has the same diameter as the rest of these and will it work on my skunk2 mani which is on a b18c1 head?
loud3nergy
18
Jun 1, 2006 09:18 AM
