crazy shake under acceleration
Old May 3, 2007 | 04:48 PM
deftonerider's Avatar
Default crazy shake under acceleration
hey ht,
before anything i want to say that i've already checked that
alignment is within spec (other than neg camber)
tires are all same size and inflated, and balanced
all mounts are in good condition and are innovative mounts
and the axle has been replaced and even tried on a buddys car and was ok
everytime i accelerate hard the wheel begins not vibrating but shaking almost out of my hands, and it is only at above 30+ mph and under acceleration, when i let of and start to brake it goes away,
Steeing rack makes wierd noise when i turn one way but not the other. could a bad rack shake the car, if so does anyone know if a crx si rack and pinion would fit, even if i replaced the inner and outer rods
Old May 3, 2007 | 10:39 PM
Legion's Avatar
* B A N N E D *
Default Re: crazy shake under acceleration (deftonerider)
Wait, so you didn't check for warped rotors?! That's the number 1 cause of the symptoms you described.
Old May 4, 2007 | 05:57 AM
NathanielH's Avatar
Default Re: crazy shake under acceleration (Semtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Semtec &raquo;</TD></TR><TR><TD CLASS="quote">Wait, so you didn't check for warped rotors?! That's the number 1 cause of the symptoms you described.</TD></TR></TABLE>
Old May 4, 2007 | 07:37 AM
shake goes away under decel or braking
Old May 4, 2007 | 12:02 PM
NathanielH's Avatar
Default Re: (deftonerider)
I got what you said deftonerider, wich is why i was questioning semtec's responce...dosent seem logical
Old May 4, 2007 | 06:46 PM
boostedblkef's Avatar
Default Re: (NathanielH)
in for answer my car does the same **** but no weird noises im leaning towards ball joint or mounts
Old May 4, 2007 | 08:32 PM
donnie_437's Avatar
yea..check for loose mounts. one screw from any mounts can cause that problem.
Old May 4, 2007 | 09:57 PM
phoenixyellowda9's Avatar
Default Re: crazy shake under acceleration (donnie_437)
i have the same problem and my mechanic says its the rack n pinion who knows???
Old May 5, 2007 | 04:10 PM
vpower101's Avatar
i once saw a guy on ht that was claiming he but a crx si rack and pinion on his da integra and it worked fine cut out like 20-30 lbs, he claimed that as long as you use the crx si inner and outer tie rods it will work, i cant remember where i saw that, can anyone that has this setup give me a heads up
Old May 6, 2007 | 07:23 AM
NathanielH's Avatar
Default Re: (vpower101)
After rereading your post, i would definitly agree that your rack could be the issiue. Have you jacked up the front of your car and checked for play in the tie rods/rack/balljoints/front suspension?
Old May 6, 2007 | 08:22 AM
93supercoupe's Avatar
ive had a few B series do that.
I figure it was the trans or unbalanced cluutch/f;ywheel.
Old May 7, 2007 | 09:00 AM
bump anyone else
Old May 8, 2007 | 05:38 AM
NathanielH's Avatar
have you checked out your front steering and suspension components yet? it truley isnt that hard. No one is going to be able to tell you with certainty what the problem is, unless they have the car in front of them.
jkm211
Sep 7, 2009 12:53 PM
Sean @ ESG
Feb 18, 2007 09:12 AM
faSHOwidIT
12
Feb 12, 2007 09:40 PM
beyondspexj
Jan 26, 2006 11:12 PM
Caoboy
Jan 12, 2004 10:44 AM
