Setting timing
Old Aug 28, 2018 | 01:14 AM
Terry Langel's Avatar
Default Setting timing
How can you set valves if the belt broke without being at TDC. Do i need to pull the head off the block.
Old Aug 28, 2018 | 04:19 AM
hondamark35's Avatar
Default Re: Setting timing
title says "setting timing" or timing the cam/ignition to the crank, but then you talk about "set[ting] valves" which would normally refer to valve lash. clarify what you're trying to do.
maybe you're trying to check for damaged valves after the belt broke? just lift the rocker assembly off. it doesn't matter where the timing is necessarily. may help to have the cylinder you're pressurizing (checking for leaks) at BDC so it doesn't spin on you.
if you need valves to be open with a timing belt off, just put the crank 90° off TDC in either direction. that'll put all four pistons about mid stroke and clear of the valves.
brickinthewall
Jan 23, 2015 01:01 PM
accordforme
Oct 8, 2010 08:03 PM
JSpekBB4
Sep 5, 2006 08:02 PM
JSpekBB4
Sep 1, 2006 08:18 PM
shbrown
May 27, 2005 07:58 AM
