Crankshaft Turned
Old Apr 27, 2005 | 06:16 PM
BbOi0420's Avatar
Default Crankshaft Turned
Scenario: I was in the process of removing my flywheel off my new motor, 2 bolts were stuck, had to grind the heads off, ended up turning the flywheel in both directions multiple times.
So, my questions are these: Is this bad? If so, how bad? How hard to fix? Is it even fixable whatever i did.
Thanks
Old Apr 27, 2005 | 09:08 PM
zacdaddy77's Avatar
Default Re: Crankshaft Turned (BbOi0420)
multiple times.......... like 4 or 5 or like 50 or 60?
Old Apr 28, 2005 | 12:57 AM
BbOi0420's Avatar
Default Re: Crankshaft Turned (zacdaddy77)
like 4 or 5
Old Apr 28, 2005 | 07:55 AM
tgreaves's Avatar
Uhh.. Im kinda confused here.. You were removing flywheel bolts and you turned your engine and flywheel a few times while grinding the heads off the bolts?????
Old Apr 28, 2005 | 09:06 AM
zacdaddy77's Avatar
Default Re: Crankshaft Turned (tgreaves)
it should be ok but ig you want to be sure you'll have to take her apart
Old Apr 28, 2005 | 12:32 PM
Honda Hick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">Uhh.. Im kinda confused here.. You were removing flywheel bolts and you turned your engine and flywheel a few times while grinding the heads off the bolts?????</TD></TR></TABLE>
I'm confused to. Why would it be a problem turning the crank? As long as you had a timing belt on there and the cams turned you wouldn't have any valve to piston contact. I don't see the problem, maybe you can explain more.
Old Apr 28, 2005 | 11:34 PM
BbOi0420's Avatar
Default Re: Crankshaft Turned (Honda Hick)
i dont know why it would be, thats why i was asking. I heard it was.
Yes, i turned the fly.
Old Apr 29, 2005 | 05:26 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BbOi0420 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, i turned the fly.</TD></TR></TABLE>
So you just rotated the engine a little, since everything else it hooked up you didnt hurt anything at all..
Old Aug 10, 2005 | 10:51 PM
EnzoSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zacdaddy77 &raquo;</TD></TR><TR><TD CLASS="quote">it should be ok but ig you want to be sure you'll have to take her apart</TD></TR></TABLE>
Lol, I know this is an old thread, but I had to laugh when I read that comment.
JDMInspired
Honda Civic (2001 - 2005)
Mar 17, 2008 08:57 AM
Muckman
Jul 13, 2004 07:31 PM
Georgethefierce
Aug 3, 2003 08:54 AM
vtec69
Apr 12, 2003 10:23 AM
89civic1.8T
Mar 25, 2002 08:15 AM
