With crank to use on LSVTEC (gsr,ls)
hi one of my buds is giving me a gsr crank and im building a low costly lsvtec. SHould i go with the gsr crank or ls crank. Or what crank is the best overall for a turbo setup.
i would say keep the ls crank. if you go gsr you would need the gsr rods and there really isnt a big issue with the ls crank. sell the gsr crank and use the money to buy arp rod bolts for your ls pistons and you should be fine
good luck.. gsr is better(stronger) tho some people say...
