Crank Scraper CONS
Old Jul 12, 2004 | 12:26 PM
Combustion Contraption's Avatar
Default Crank Scraper CONS
http://www.crank-scrapers.com/....html
While looking at the link posted above, it seems like a no-brainer. However, if they were so efficient at freeing up horsepower, why didnt high performance vehicles(think k20a - b18c) come with these from the factory? Can anyone forsee any problems caused by using these/had actual experience using them? Thanks in advance.
Old Jul 12, 2004 | 12:27 PM
Ivrit
Guest
Posts: n/a
As long as its properly installed, there really is no “consâ€
Old Jul 12, 2004 | 12:51 PM
You dont think it prevent the cylinder walls from being properly lubed?
Old Jul 12, 2004 | 01:02 PM
Ivrit
Guest
Posts: n/a
Default Re: (LsVtec92Hatch)
nope. not at all
Old Jul 12, 2004 | 01:17 PM
StyleTEG's Avatar
Default Re: (Ivrit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivrit &raquo;</TD></TR><TR><TD CLASS="quote">As long as its properly installed, there really is no “consâ€</TD></TR></TABLE>
Old Jul 12, 2004 | 01:19 PM
sweet. this sounds like a really easy/beneficial mod.
Old Jul 12, 2004 | 01:23 PM
StyleTEG's Avatar
Its kinda PITA to install.
Might be easier when the engine is on a stand and out of the car.
Since you are fighting gravity, you have to hondabond the scraper to the block, while holding it with the oil pan bolts. Once it dries to the point of supporting itself, you can remove the bolts and bolt the pan back on.
Hopefully you don't get any leaks as you are relying on liquid gasket instead of a rubber one (like the stock oil pan), and hopefully if you ever have to remove the pan it doesn't losen and shift.
Myroslav69
May 6, 2010 11:39 AM
Myroslav69
Southeast (Sales)
19
Mar 20, 2010 09:08 PM
Myroslav69
Mar 12, 2010 06:05 PM
Godspeed07
32
Jul 28, 2008 03:08 PM
eg4matze
Acura TSX
19
Nov 23, 2004 09:51 AM
