Crank No Start PLEASE HELP
Old Feb 27, 2016 | 06:45 PM
Elijahdaniel's Avatar
Default Crank No Start PLEASE HELP
Hey guys I live in Florida have a 1992 Honda accord ex automatic and I am getting a strong start everytime but wont turn over when it was running cold start in morning it would start rough and I would have to pump gas to get it started then ran rest of the day and started fine . now just motor is turning but no start I have fuel in main fuel line fuel pump is on and working I'm getting good fire just changed rotor button on distributor and the coil pack is getting fire off the distributer main relay is good replaced it just for hell of it . I am really stuck on this one it cranks at 2 different speeds when I try to start it fast then normal sometimes but never turns over tryed starter fluid for hell of it as well.. Amy help on this would be greatly appreciated !!!
Old Feb 27, 2016 | 07:07 PM
motoxxxman's Avatar
Default Re: Crank No Start PLEASE HELP
check for any stored trouble codes, and fix anything that comes up. if there are no trouble codes stored, check all fuses. if all fuses are good, do a fuel pressure test; the fuel pump and/or fuel pressure regulator might be failing. or the fuel filter might be clogged, or the fuel pump sock might be clogged.
hell, just do a full tune up, I'm positive it needs all of the following:
VALVE LASH ADJUSTMENT!!! - this should be checked/adjusted every 20k miles. most people never check it for the entire life of the car, and wonder why it runs like crap. valve adjustment has a HUGE HUGE HUGE impact on how well the engine runs
cap and rotor (yes you replaced the rotor, but did you replace the cap too?)
plug wires - NGK ONLY!!!! NOTHING ELSE!!!!
fuel filter
oil change
air filter
Kid-jdm-teggy
Sep 13, 2013 09:20 AM
DA9b0y303
29
Aug 21, 2013 03:51 PM
turboteg7
Dec 21, 2008 11:12 AM
blu3g
May 29, 2008 05:18 PM
pbizzlegsr
Aug 27, 2004 08:55 AM
