Could someone technical identify this head (Pics)
Old Jul 17, 2010 | 11:21 AM
Aim-MDMA's Avatar
Default Could someone technical identify this head (Pics)
I bought this head and cams very cheap and was told from the guy i bought this from it was a 97 Integra GSR head.
Im looking to put this on my MB6 as i have some blue smoke, i have done some research but cant really find a definite answer to what kind of head this is.
It has dual valve springs on 1 side of the head and single on the other. but it also missing the cam caps (i have been told these will transfer from my b18c4 head??? but im not holding my breath)
will this be a decent upgrade to my mb6 with a dc2 ITR bottom end, if not will the cams be any advantage over my standard b18c4 cams?
The head has stamped on it PR3-1 (which i think is NOT a GSR, and its dated 1997)
Thanks in advance for your help folks
Old Jul 17, 2010 | 12:38 PM
non-VTEC's Avatar
Default Re: Could someone technical identify this head (Pics)
looks like a B16 head...still fine. the cams also look to be B16 cams you may want to sell those for something more aggressive.
Old Jul 17, 2010 | 12:59 PM
kyden's Avatar
its a b16 head.. but you might run into trouble with mixing cam caps...
Old Jul 17, 2010 | 01:12 PM
Aim-MDMA's Avatar
Thank you for the reply, i take it my b18c4 cams are better than these then, do you know if these cams are from a 1.6 vti? sorry im not very good with all the numbers hondas have for the engines.
Will i still need to upgrade the valvetrain to allow for more aggressive cams? and what about the cam caps, can i interchange with my b18c4 parts?
if nothing is of any use to my mb6, springs, valves etc i will just sell the head on
Thanks again, any info is much appreciated
Old Jul 18, 2010 | 07:03 AM
riceburner700's Avatar
if you swap cam caps i would have a machine shop check out the journals because each set of cam caps is machined perfectly to each head and yours more than likely will not line up with the next head and cause came seizing/scoring unless you have it line bored
Old Jul 18, 2010 | 07:53 AM
Str8EJ's Avatar
I don't think you should remove the cam caps from your head and modify them to fit this one. I think you should just rebuild your current head and sell this one for parts. Either that, or find another incomplete/damaged head to score the cam caps for the new purchase. As stated previously, it will still require machining in order to work.
Rebuilding a cylinder head to factory specs doesn't take very much time and a competent machine shop could complete the work within one week. In that process, it's just as much effort to reinstall the original valve springs as it is to install aftermarket ones.
The real world difference between GS-R and B16a cams is negligible.
Old Jul 18, 2010 | 09:07 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Your cam caps will not work. To get the camcaps lined bored to work you need to find a competent machine shop first. Second you need to shell out more money than you paid for the head. Not worth it IMO. The seller suckered you.
Old Jul 18, 2010 | 10:36 AM
Aim-MDMA's Avatar
oh well alot of other people say it can be done but if it will cause possible problems then im not going to do it, i only paid £100 for the whole lot so i will surely make the money back selling it on.
The reason i bought the head was so i could have it all rebuilt, ported & polished and any other work needed, then just swap heads with my own.
I cant really have alot of downtime on my car as it my daily and have no 2nd car for getting to work.
I guess i will just have to source a complete head,
Thank you for your help, i guess we all learn from our mistakes
Old Jul 18, 2010 | 11:00 AM
Str8EJ's Avatar
If it makes you feel any better, the price, converted to USD, isn't all that bad all things considered. The misc parts, like the valves, LMAs, etc., could be worth something. The head casting would be great for someone who wants to practice diy porting.
I wouldn't consider it a bad purchase, necessarily. Just not what you need.
Good luck.
Bgesy
Feb 28, 2007 09:12 PM
BodyKits NW
Feb 14, 2006 10:46 PM
VtecRacaChick
Jan 29, 2004 10:30 PM
JDMvtecDRAGSTA
Apr 18, 2002 12:07 PM
