could bad alignment cause wheel hop
Old Aug 16, 2004 | 12:56 PM
dornon13's Avatar
Default could bad alignment cause wheel hop
does anyone know if this is a cause of wheel hop possibly?
Old Aug 16, 2004 | 01:23 PM
87quest's Avatar
Default Re: could bad alignment cause wheel hop (dornon13)
doubtfull but a tire out of ballance or a bad strut would more than likely be the culprit, sometimes stock suspension geometry is the bad guy!! are you lowered??
Adam
Old Aug 16, 2004 | 01:29 PM
dornon13's Avatar
Default Re: could bad alignment cause wheel hop (87quest)
unfortunatly i bought it lowered...and it has a big camber problem in the back but if the front is bad then its not noticable...regardless i gotta get it aligned but i was curious just wanna get the wheel hop fixed before the engine goes in
Old Aug 16, 2004 | 02:02 PM
mmuller's Avatar
Mad Scientist
do an alignment for toe, camber doesnt affect much unless very radical.
get new bushings and fill/buy inserts for the rngine mounts.
It will help you a lot
Old Aug 16, 2004 | 02:18 PM
vtec69's Avatar
well try this to fix the rear camber
works great and only costs like $6
http://home.earthlink.net/~civ....html
Dragsparks
24
Dec 17, 2009 05:35 PM
zbra09
Suspension & Brakes
Oct 5, 2008 07:41 AM
TEG98
Apr 6, 2003 08:33 AM
GoLowDrew
Mar 25, 2002 09:02 AM
