Cooling fan dosn't turn on? overheating
Old Mar 18, 2007 | 02:10 PM
Paluce's Avatar
Default Cooling fan dosn't turn on? overheating
Ok, so my cooling fan isn't turning on. I blew my cooling fan fuse a few months ago because I had a wrench loged in there my mistake! Now that i replaced the fuse, I thought everything would be ok. But the car overheated a bit today. I check the cooling fans, and the main fan wasn't turning on. When I turn the AC on, both kick on and the car cools off. Also, when I drive, the temps come down so the thermostat is open and ok. I also checked the cooling fan relay. It clicks.
Any thoughts???
Old Mar 18, 2007 | 07:18 PM
JimBlake's Avatar
Default Re: Cooling fan dosn't turn on? overheating (Paluce)
How high did the gauge get? It's supposed to go up a bit before the fan switches on.
Jumper the fan switch, see whether that switches the fan on. If so, the rest of the circuit it OK leaving (probably) a bad fan switch.
Old Mar 19, 2007 | 04:08 AM
Paluce's Avatar
It went about 3/4 up the gauge, way too high. I also looked at the temp via my laptop and Hondata. 224F Too hot!
Where is the fan switch located?
Old Mar 19, 2007 | 04:30 AM
JimBlake's Avatar
Default Re: (Paluce)
Usually on the thermostat housing. But that depends on what year/model you're talking about.
Old Mar 19, 2007 | 08:45 AM
Darth_Accord90's Avatar
224 degrees isn't really that hot for a 4-banger. Remember that 4 cylinders have to work a bit harder than v6's or v8's and usually run a bit hotter. And like Jim said, your temp has to get to a certain level b4 the fans kick in. If you run down the highway alot, ur fans wont even kick on, but will in slower areas like city streets.
Old Mar 20, 2007 | 09:33 AM
Paluce's Avatar
Ya, the fans turn on at 200 in my lude. and I cought the temp at 224, it was rising fast, so it was a problem. I was idling.
But All is fixed now. temp switch.
Thanks to all!
apexi_rsx
Jul 19, 2013 07:43 PM
Shinwasha
Feb 17, 2012 07:50 AM
brickerj
Dec 22, 2011 02:08 PM
jlowellintegra
May 30, 2011 07:52 AM
cslegacy
Jan 12, 2007 11:59 PM
