Cooling additive opinions
Old Aug 3, 2010 | 11:32 AM
Tunerguy1989's Avatar
Default Cooling additive opinions
I plan on flushing my cooling system soon and I'm planning on putting wet-wetter additive in there because import tuner proved that it worked. But does anyone have any opinions on cooling additives in general (royal purple, wet-wetter, etc.) or a link to a reputable place that has reviewed these kind of additives.
Old Aug 3, 2010 | 12:22 PM
Scott_Tucker's Avatar
Default Re: Cooling additive opinions
Water wetter is very good. Since you live in Sac and it doesn't get that cold you can run very little anti-freeze type coolant. I would run like 10% just in case you have a cold snap. Water has about twice the heat removing capacity that anti-freeze so combined with the water wetter it will remove heat very effectively. The only time you should run more is if you occasionally go up to Tahoe or something where it gets below freezing.
BLK2DOOR
Jun 13, 2010 01:29 PM
Elwuudz
10
Mar 14, 2008 09:07 AM
Hondaciv95VX
Jan 13, 2005 07:21 PM
Chris Sawatsky
38
Jun 21, 2004 10:06 AM
05 600RR
Jul 17, 2002 11:56 AM
