Coolant Problems
Old Jan 1, 2004 | 12:32 AM
JDMHondaPro's Avatar
Default Coolant Problems
today i put a D-Series back in my civic (use to have a B-Series, but thankx to Hasport cable to hydro conversion. IT FELL OUT). i hooked up all hoses, coolant, oil, etc. . i put all the liquids in, oil, coolant, and trans fluid. run the car for a lil bit and the engine starts smoking like it is over heating. the temp gauge stays in the middle. i thought it might be the thermostat, so i went and squeezed the hose. all hoses are full wit fluid but one. the one on the bottom of the radiator leading to the thermostat is empty. even the hoses behind the thermostat is full wit coolant and hot. but that hose is empty. do u think i didnt bleed it right? if so, how do i bleed a D-Series (on the B-Series u have the bleeder valve)?
Old Jan 1, 2004 | 06:36 AM
doublejz's Avatar
Default Re: Coolant Problems (JDMHondaPro)
Just rebleed it. Squeeze every inch of the hose, to force air outta the lines, you'll be fine.
Old Jan 1, 2004 | 08:27 AM
Default Re: Coolant Problems (doublejz)
so how do u bleed a d-series?
Old Jan 4, 2004 | 09:45 AM
EvilPinkEye's Avatar
there is also a small bolt right in front of the block on the top hose,
loosen it a bit and, slap the heater on full blast. let the engin idle for a bit as well and watch the flow come out of the bolt that u loosed to see that it flows out evenly, dont squeeze the top or bottom hose to speed things up, it just sucks more air in. tighten when done of course then finish filling the system.
Old Jan 14, 2004 | 05:27 PM
Default Re: Coolant Problems (EvilPinkEye)
na that nipple is not on the D-Series i have. but i got it thankx
caseythefalcon
May 5, 2014 10:56 PM
MJOLNIRvTEC
Aug 18, 2008 05:37 PM
turbotime
78
Aug 3, 2005 05:09 PM
Paprika
Dec 21, 2004 04:51 AM
tFUnK
Jan 2, 2003 12:56 AM
