considering V6 swap
Old Jul 15, 2013 | 09:22 AM
  #26
Orangevirus1's Avatar
Default Re: considering V6 swap
Originally Posted by NVturbo
I don't know where you're getting these ridiculously low prices from. Must be from that shop that has no name or telephone number on the building.
From your suggestions of gauges, I highly doubt you have the knowledge to even put the motor in. How's that for some insightful post??
well the engine, from a wrecking yard in a city about 100 miles away.
the transmission, car-part.com
and nope. I have no ******* clue what i'm doing. not at all. what the **** is a throttlebody i'm lost.
I've done quite a few engine swaps on cars. not hondas, but other cars. so you can just see yourself out.
Jeese while I'm at it I should replace the flux capacitor too? I will come to you personally for all my swap woes. How do I change out a fuel injector? intake manifold what the **** is that?
I don't even understand how I bolt the flywheel to the axles..
Old Jul 15, 2013 | 03:56 PM
  #27
misterEJ's Avatar
I've seen the prices of all this before and that sounds kinda low but could be done. Tranny might be hard to find. I'm sure there will be some odds and ends that will all add up which I bet you would assume as well. Such as stiffer front springs, fuel pump, ecu, shifter, and wiring harness. I don't think it really matters how much experience this person has as long as he has a lot of determination. Less experiencing just means more learning.
Also op, if you have rpm systems modify the harness you can also use your 4cyl tach with your cluster I believe. It would be worth it if you're not strapped for cash like me lol. And you'll have a lot of understeer. Just play around with suspension, swaybars and probably braces too
Old Jul 15, 2013 | 04:02 PM
  #28
that's what I plan. I have a fully adjustable suspension. hopefully the tokico's can handle the added weight.
I'm not really trying to do this on a hobo's budget. not gonna cut corners.
I have swapped quite a few engines in cars before.
hell I swapped blocks in my honda just a week ago. I was surpised it's so light. I just picked the short block up and put it in the engine bay lol
factoryhondaparts
Sep 22, 2010 10:57 AM
SubLime_H22
Aug 17, 2010 06:27 PM
vtec-adykt
May 12, 2006 06:16 AM
03akkord5spd
Jan 20, 2006 11:42 AM
HondaH22A
Dec 25, 2002 04:20 PM
