Coned Cylinders and Hp Loss
Old Nov 12, 2004 | 04:39 PM
1BadCvC's Avatar
Default Coned Cylinders and Hp Loss
Just curious bc right after the dyno numbers that i put down, in my sig.. We took the block apart bc it was burning 2 quarts every 3 days and the PTW clearances were 5 thousandths at the bottom and over 10 thousandths at the top of the piston. max clearance should be 5 thousandths i think. How much power could be lost bc of this?
Old Nov 12, 2004 | 09:56 PM
Denny Crane's Avatar
Default Re: Coned Cylinders and Hp Loss (1BadCvC)
Too much. Bore it out or sleeve it and buy new pistons and rings.
Old Nov 12, 2004 | 09:59 PM
mmuller's Avatar
Mad Scientist
wow.
what kind of pistons do you have in there?forged?
Old Nov 13, 2004 | 05:45 AM
1BadCvC's Avatar
Default Re: Coned Cylinders and Hp Loss (mmuller)
They where forged JE 12.5:1 84mm bore and yea i had to resleeve it and increase the bore again. Im surprised the motor even ran somewhat quietly with that big of clearance issues in the first place. But can any significant power be lost from this?
Old Nov 13, 2004 | 08:09 AM
Huh? I thought you were expressing PTWC as a means to determine the straightness of a cylinder. My bad if that's the case.
Btw, some pistons are measured 90 degrees from the pin hole but it's up to the piston manufacturer to determine how you actually measure a piston. Many pistons are cam ground, meaning they're slightly oval in shape. I wouldn't use top ring land to cylinder wall clearance as a means to determine piston wear. Some top lands are intentionally machined slightly smaller anyway.
Forged pistons grow the most, far more than cast and especially glass pistons, so they require much greater clearances.
Old Nov 13, 2004 | 08:15 AM
mmuller's Avatar
Mad Scientist
well, power thats scaping through the rings is lost power; so im mean...
thats a shitload of ptwc. shouldnt your clearance be around 3 thou.
Old Nov 13, 2004 | 02:25 PM
1BadCvC's Avatar
yea clearance should be round 4 or so, least i can hope for some better numbers next round at the dyno
Old Nov 13, 2004 | 06:31 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1BadCvC &raquo;</TD></TR><TR><TD CLASS="quote">yea clearance should be round 4 or so, least i can hope for some better numbers next round at the dyno </TD></TR></TABLE>
are you spraying? if not then i would go the smallest ptwc that the piston allows for. im not sure what JE calls for.
Old Nov 13, 2004 | 09:48 PM
notstock93's Avatar
How exactly can you cone the top of the cylinder but keep the bottom without tolererance? Piston slap? sideloading forces?
Old Nov 13, 2004 | 09:57 PM
mmuller's Avatar
Mad Scientist
Default Re: Coned Cylinders and Hp Loss (notstock93)
usually when you run lots of tolerance the cyl. will oval shape.
Old Nov 13, 2004 | 10:01 PM
notstock93's Avatar
Ah, oval. I had a picture of a perfectly round circle gaining diameter in my head.
An oval or out of round bore makes more sense.
Old Nov 13, 2004 | 10:19 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
that much wall clearance is costing you a ton of cylinder pressure.
..honing without a deckplate and hot hone fluid circulating will mean the block distorts when head is torqued and its hot.
Old Nov 13, 2004 | 10:26 PM
mmuller's Avatar
Mad Scientist
Default Re: (mike_belben@yahoo.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike_belben@yahoo.com &raquo;</TD></TR><TR><TD CLASS="quote">
..honing without a deckplate and hot hone fluid circulating will mean the block distorts when head is torqued and its hot. </TD></TR></TABLE>
most hondas are open deck design...
Old Nov 14, 2004 | 11:34 AM
Default Re: (mmuller)
Agreed. That would be true on a closed deck sbc where the head literally bolts onto the cylinder walls. Much less true on other closed deck designs where the bolts grab along the block's inner and outer walls (traditional Pontiac V8, etc.). It's irrelevant on open decks where the head bolts to the block's inner and outer (front and rear, left and right?) walls.
Old Nov 17, 2004 | 09:46 PM
Default Re: (hybrid2nr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid2nr &raquo;</TD></TR><TR><TD CLASS="quote">... It's irrelevant on open decks where the head bolts to the block's inner and outer (front and rear, left and right?) walls. </TD></TR></TABLE>
irrelevant is a strong word. i agree unnavoidable for closed cast iron decks and maybe something you can get away with on open decks, but still considerable for any engine if the hone is intended to be taper free to the tenthousandths place.. which should be a goal if nothing else. a high end honejob is done with a deckplate regardless. for skipping such a simple, easy, inexpensive step, i dont consider a shop who doesnt use honing plates to be high end or particularly specialized.
rereading the post and considering a whopping .005" taper, i will change my answer to:
"incompetent hone operator"
Lindomar85
Sep 7, 2013 05:09 AM
5_Lug_B
Aug 5, 2007 09:26 PM
giomfe
Nov 19, 2006 09:00 AM
siis2fast
Jun 7, 2005 03:52 AM
95c1v1cs1
Jul 28, 2004 09:44 AM
