compression tester ?s
Old Jul 10, 2002 | 08:27 PM
Pengo's Avatar
Default compression tester ?s
any recommendations on this before i go out and purchase one?
i dont have any experience with this, so i dont know if there are different types or things i should look out for. or are all the same? can anyone help?
thanks
Old Jul 11, 2002 | 11:34 AM
Perfectionist's Avatar
Default Re: compression tester ?s (Pengo)
Just recently bought one for about $29 plus change. It came with the adapter for long plug threads. It may not be 100% acurate, but the main thing you are looking for is not the PSI, it's the variation between cylinders. For casual use it's just fine. Just my $.02.
Old Jul 11, 2002 | 01:04 PM
brcivic411's Avatar
Default Re: compression tester ?s (Perfectionist)
summit has a non-expensive one you might want to check out
Old Jul 11, 2002 | 02:20 PM
Pengo's Avatar
Default Re: compression tester ?s (brcivic411)
thanks alot for the help guys
Old Jul 11, 2002 | 04:41 PM
kwil666's Avatar
You can find them on ebay or at your local auto parts store. I would get a somewhat good one. Its not like its a leak down tester, a good one of those would cost some money.
Keith
Old Jul 11, 2002 | 05:03 PM
FSTASNTZ's Avatar
Default Re: compression tester ?s (kwil666)
Some of the ones out there only go up to 240-260, some go higher. Being someone with high compression, I would say look for a 300+ gauge. At 12.38:1 compression, I bottom the gauge out at 300 psi...
Jason
Old Jul 11, 2002 | 05:37 PM
Pengo's Avatar
Default Re: compression tester ?s (FSTASNTZ)
i found two so far that i am considering. they both have identical specs and features, the only difference being that the one from sears has a black face and the one from summitracing has a white face. both go up to 300, with the sears going for 24.99 and the summit on going for 21.99. i'll prob end up with the one from sears as i can go get it in one day and i wont have to pay s&h fees.
i think 300 should be more than enough on my sohc rite? i doubt i'll need a tester that read that hi
if anyone could recommend any other low priced brands that work well, feel free to let me kno
thanks again
boosted92hatch
Feb 21, 2008 11:07 AM
EARLdaSQUIRREL
Nov 25, 2006 07:05 PM
Petah
Aug 19, 2003 11:37 PM
ITR22
May 7, 2003 10:17 PM
Nameless RB26
Apr 10, 2003 01:53 PM
