Compression Test, are they about right?
91' CRX Si D16a6 SOHC nonvtec
145, 140, 145, 150
decent numbers? or not... I also have a stage3 cam w/ 270 duration and im not sure if taht would effect the numbers.
145, 140, 145, 150
The cam shouldn't affect the numbers because you should measure compression at TDC before what would be the power stroke (assuming the engine was running) when all of the valves in that cylinder are shut.
Those numbers seem really low to me. I would suggest to do a leak down on the motor and are you sure you put the cam in correctly along with the timing belt? Also is your head milled at all.
Couldn't my cam be the cause of the lower compression #'s?
Stock cams cause valves open and close quicker, so during the stroke the cylinder has more time to compress while the valves are closed
This is a Stage3 w/ 270 duration race camshaft, Would it be why?
Aftermarker cam w/ longer duration keeps the valves open longer so while during the stroke the valves are still open releasing air, thus giving a lower compression number because less air was compacted.
This is an untuned cam w/ stock camgear.
Typesi2nv is correct. the cam WILL have a impact on compression test results. you guys should search and you will also learn this.
those numbers look perfectly fine for the year/engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc231 »</TD></TR><TR><TD CLASS="quote">The cam shouldn't affect the numbers because you should measure compression at TDC before what would be the power stroke (assuming the engine was running) when all of the valves in that cylinder are shut.</TD></TR></TABLE>What??Yes it will affect the readings.valves are open longer and will bleed off more pressure at low RPM such as when doing a compression test.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fkned »</TD></TR><TR><TD CLASS="quote">What??Yes it will affect the readings.valves are open longer and will bleed off more pressure at low RPM such as when doing a compression test. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC »</TD></TR><TR><TD CLASS="quote">Typesi2nv is correct. the cam WILL have a impact on compression test results. you guys should search and you will also learn this.
those numbers look perfectly fine for the year/engine.</TD></TR></TABLE>
thanks
see.. I knew i wasnt crazy all along.
naa, I have known about that for a while but too many people were trying to tell me i was crazy and i was wrong.
thanks
JDMs1eeper
Nov 10, 2003 01:06 PM
JDMs1eeper
Nov 5, 2003 09:55 AM
