compression test results
Old Jul 11, 2004 | 06:58 AM
roadawg's Avatar
Default compression test results
230 235 130 240
This is a 1g b16, its stamped 90.
It trapped at 94 MPH last month so I think she's healthy, but the numbers don't lie.
Can low compression hurt HP??
What are possible causes of such low compression in the #3 cylinder?
Old Jul 11, 2004 | 07:30 AM
KMaxwell's Avatar
Default Re: compression test results (roadawg)
you should get a leak down tester, that will tell you if you bent a valve or need rings, etc. that will be your next step and yes that will affect hp
Old Jul 12, 2004 | 06:41 AM
roadawg's Avatar
Default Re: compression test results (KMaxwell)
Is it possible that hitting the manhole cover somehow bent a valve?? I mean it hit hard!!! It broke 3 exhaust manifold bolts right off, smashed the donut and the end of the header and knocked the muffler right off the piping, like I said it hit hard as ****..
Will the loss of compresion get worse with time??
Old Jul 12, 2004 | 07:35 AM
sinatra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roadawg &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible that hitting the manhole cover somehow bent a valve?? I mean it hit hard!!! It broke 3 exhaust manifold bolts right off, smashed the donut and the end of the header and knocked the muffler right off the piping, like I said it hit hard as ****..
Will the loss of compresion get worse with time?? </TD></TR></TABLE>
I don't think the man hole cover impact itself could cause this but driving around with the pinched exhaust could.
Low compression just indicates that rings are smoked, could also indicated problems in the valve train. Are you experiencing any blue smoke when stepping on the throttle?
I would also recommend a leakdown test. That will help you find where exactly you are losing the most compression.
Old Jul 12, 2004 | 08:16 AM
roadawg's Avatar
Default Re: compression test results (sinatra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinatra &raquo;</TD></TR><TR><TD CLASS="quote">
I would also recommend a leakdown test. That will help you find where exactly you are losing the most compression. </TD></TR></TABLE>
Nope, no blue smoke when I hit the throttle hard, but it does smell like something is burning now at high RPM. I am definitely doing a leakdown test soon to find out exactly what that problem is.
Thanks for the replies.... BTW your avatar rocks!!
Honda owner
13
Feb 22, 2006 12:45 PM
carlos11
Aug 5, 2005 09:17 AM
the.hamburglar
May 7, 2004 07:00 PM
Slammed2K1
Dec 5, 2003 07:35 PM
EF8_SiR
Jul 20, 2003 10:24 PM
