Compression Ratios
Old Jul 1, 2002 | 09:16 PM
Briman2021's Avatar
Default Compression Ratios
I am planning on building up a N/A d16y8 mtoor and I have a few questions...
1.)What would be the highest compression I could run on 90 or 92 octane gas??
2.)How much would it cost to get pistons installed, assuming I would need my block bored out??
3.)How much would the said pistons cost??
4.)Would I need new rods to go with the pistons??
5.)Also, what other parts would I need to make a higher-compression setup work??
Thanks!!!!
Old Jul 1, 2002 | 09:27 PM
cj7420's Avatar
New User
Default Re: Compression Ratios (Briman2021)
stock is like 9.2 and needs only 86 oct. with stock timing
the only pistons I've seen are turbo at 9:1 and NA at 11:1
don't know anything else but at least your back to the top
Old Jul 6, 2002 | 05:18 PM
Briman2021's Avatar
TTT
I really need help, nobody seems to be able to answer this question anywhere else.
Please Help!!!!!!
Old Jul 6, 2002 | 05:59 PM
non-VTEC's Avatar
depending on the avalibility of fuel in your area you can be safe with 12:1CR on 91-92 octane.
how much will it cost to put them in? call the machine shop that will be doing the work and find out.........
how much for pistons? depens who/where/what kind of pistons you buy........they range from 350-500 for a set of good forged pistons.
new rods would be a good investment if you plan to rev it alot and if you plan to make alot more power over stock.
high compression pistons love high lift long duration cams. choose a good cam that will suit your application. also consider haveing the cylinder head ported...it will make the engine breath much better.......
good luck!
[Modified by non-VTEC, 10:01 PM 7/6/2002]
Old Jul 6, 2002 | 06:26 PM
trbob16a's Avatar
1) 12.5:1
2) 150-300
3) ~450
4) No
5) Stand alone and larger injectors
I suggest you seriously consider a swap before investing a couple of thousand dollars in injectors, stand alone, high compression, and installation on a d series motor. You will not be that impressed with an all motor d series engine. You can do a b16 swap into just about any car for a couple of thousand dollars, and your car will be putting out ~135whp stock with lots of potential in the future. Another $500 for nitrous and you drop another second off your time.
There are cheap ways to be fast, and there are stupid ways to be slow. Your choice.
traumatrix89
Feb 24, 2011 09:02 PM
phantom_bcw84
Jan 3, 2007 09:10 PM
91(si)hatchey
Sep 4, 2006 10:25 PM
LSyellowREX
Jun 16, 2002 01:08 PM
fixhondas
Aug 23, 2001 01:18 PM
