Is this compression calculation correct?
Old Jan 3, 2003 | 10:29 AM
VTEC-DA's Avatar
Default Is this compression calculation correct?
I went to the C-speedracing.com website and used their compression calculator. This is what it gave me.
USDM B18B block (81.50 mm bore)
B17A head
Stock 3-layer head gasket
Pistons:
p73-A0 (USDM ITR) - 11.8 CR
p73-00 (JDM ITR) - 12.4 CR
pct (CTR) - 13.2 CR
Are those correct? I just want to make sure before I go get a set of USDM ITR pistons for my LS/VTEC. What is needed to be done to the rods to make the pistons fit on Eagle B18B rods?
Old Jan 3, 2003 | 10:40 AM
VTEC-DA's Avatar
Default Re: Is this compression calculation correct? (VTEC-DA)
Ok, I wa just reading thier LS/VTEC buildup and it says that they used the B17A head and the P73 pistons and that gave them a 10.9 CR. Whats going on here?
Old Jan 3, 2003 | 07:13 PM
VTEC-DA's Avatar
Bump, hopefully the real tech guys come out at night.
Old Jan 4, 2003 | 04:58 AM
b19coupe's Avatar
B17A head
Pistons:
pct (CTR) - 13.2 CR
I went to C-speed and ran your numbers and came up with:
P73 (USDM)-10.904369584307167 : 1 C/R
P73 (JDM)-11.42006109553134 : 1 C/R
PCT-12.084251817988063 : 1 C/R
Note: I used the piston to deck height of OEM B18A/B/C1/C5 - B20B/Z.
Old Jan 4, 2003 | 09:48 AM
VTEC-DA's Avatar
Default Re: Is this compression calculation correct? (b19coupe)
Thanks alot. I must have just scrolled part that section. I thought my numbers were a little high.
89hb
Dec 29, 2004 11:12 AM
TwoPointZero
Jul 23, 2004 03:46 PM
HybriDNA
Aug 28, 2002 08:53 AM
Ruby Civic
Jul 28, 2002 03:40 PM
EVOCELICA
Oct 23, 2001 05:01 PM
