Compression
Why is lower compession better in a turbo?
Turbo or supercharger, which is better?
Many people just piece stuff together with no understanding how things work.
I use as low as 7.0:1 compression and if I can go lower I would ... on a FWD anyway.
Greg
When planning a turbo engine where do I look or who do I employ to help create this torbo system? Are there any sites or specific books which will help in this building of the sysytem? Thanks
The reason for lower compression in a turbo is that it increases the dynamic compression ratio. In simple terms a 12-1 NA engine at 100% volumetric efficency is 12-1 dynamic. A 8-1 turbo at boost to increace the VE to 150% is 12-1 dynamic. And, yes, cams and chamber design change the dynamic compression, but this is a simple overview. Compression is just how many times you squeese the volume of air in the cylinder from BDC to TDC.
lovey408
May 11, 2007 09:38 PM
mer2ski
11
Jan 7, 2006 08:20 AM
