Compression
Old Jun 30, 2002 | 09:47 AM
JAL1639's Avatar
Default Compression
Why is lower compession better in a turbo?
Turbo or supercharger, which is better?
Old Jun 30, 2002 | 11:30 AM
sgT's Avatar
sgT
Default Re: Compression (JAL1639)
its not better really, but it makes it easier run more boost because its
less prone to detonation.
Old Jun 30, 2002 | 11:34 AM
JAL1639's Avatar
Default Re: Compression (sgT)
Is it easy to lower compression in an engine?
Old Jun 30, 2002 | 12:59 PM
Ltech's Avatar
Yup, change the pistons and headgasket.
Old Jul 1, 2002 | 02:48 PM
JAL1639's Avatar
Default Re: Compression (Ltech)
Any certain pistons you recommend?
Old Jul 1, 2002 | 09:15 PM
B-series Assassin's Avatar
JE Pistons are good.
Old Jul 2, 2002 | 06:21 AM
CHEETAH's Avatar
the more cylinder volume you have, the more air you can fill in under boost ... downside is phase timing, i.e. the camshafts you use, intercooler piping size and size of turbo, size of TB and manifold runner diameter, etc. ... all this relative to motor size
Many people just piece stuff together with no understanding how things work.
I use as low as 7.0:1 compression and if I can go lower I would ... on a FWD anyway.
Greg
Old Jul 2, 2002 | 07:06 AM
JAL1639's Avatar
Default Re: Compression (CHEETAH)
When planning a turbo engine where do I look or who do I employ to help create this torbo system? Are there any sites or specific books which will help in this building of the sysytem? Thanks
Old Jul 2, 2002 | 07:40 AM
DonF's Avatar
The reason for lower compression in a turbo is that it increases the dynamic compression ratio. In simple terms a 12-1 NA engine at 100% volumetric efficency is 12-1 dynamic. A 8-1 turbo at boost to increace the VE to 150% is 12-1 dynamic. And, yes, cams and chamber design change the dynamic compression, but this is a simple overview. Compression is just how many times you squeese the volume of air in the cylinder from BDC to TDC.
charosenz
Jun 15, 2018 05:02 AM
smoothsedan
Apr 28, 2008 05:16 PM
lovey408
May 11, 2007 09:38 PM
mer2ski
11
Jan 7, 2006 08:20 AM
LSEGHATCH
Oct 6, 2004 07:11 PM
