Comp Cam installation
Old Oct 28, 2008 | 11:31 AM
Psychoteen101's Avatar
Default Comp Cam installation
Im installing my Comp cam into my D16 and i need a couple quick questions answered. I noticed it came in a dull black coated finish, do i install it with this finish as is? Also, i need to know where to put the cam lubricant. I was told i should put it on all contact points, is this true? Also how much should go on there?
Old Oct 29, 2008 | 03:23 AM
non-VTEC's Avatar
Default Re: Comp Cam installation (Psychoteen101)
you need to apply assembly tube to the entire camshaft before you install it. all the lobes and journals. put plenty.
as for the colour......dont worry about it. its the type of metal used during the grinding/manufacturing process that makes it the dull black finish. it will change once it kinda worn in.
Old Oct 29, 2008 | 07:29 AM
awesome thanks
PLATANOLOCO
May 16, 2010 08:20 PM
titosek4
Aug 11, 2009 06:04 PM
the king.
Jun 21, 2008 01:39 PM
guymosiris
Mar 22, 2007 07:19 AM
