Combustion Chambers
Old May 16, 2003 | 07:35 PM
I Gotta Question's Avatar
Default Combustion Chambers
What is the size in the Z6 and the size in the Z1
Old May 16, 2003 | 08:02 PM
dfoxengr's Avatar
Default Re: Combustion Chambers (89_CRX_HF)
i think theyre all 77 mm?
Old May 17, 2003 | 09:56 AM
Default Re: Combustion Chambers (hybridvteceg)
I don't understand the compression ratio in the hx is 9.3:1 and in the EX it's 9.2:1. If they had the same size combustion chamber wouldn't the one with the longer stroke have a higher compression ratio being the EX.And isn't the size measured by "cc".
Old May 17, 2003 | 10:12 AM
dfoxengr's Avatar
i was talking about the opening, not the volume. but your ? qould be true if the piston dome volumes were the same, as well as vlve sizes..which could be
Old May 17, 2003 | 10:13 AM
dfoxengr's Avatar
you shouldve aske "volume of chamber"... not size
Old May 17, 2003 | 10:55 AM
RyanEJ8's Avatar
Go here, you should be able to figure out your answer.
http://www.knology.net/~jediklc/D.htm
Old May 17, 2003 | 05:01 PM
Default Re: Combustion Chambers (RyanCivic2000)
Thanks It seems a little off though. It says the Z6 stock CR is like 9.13........or somethin like that but thanks I guess that will work
Old May 17, 2003 | 05:13 PM
It doesn't have the Z1 head on there what up?
Old May 17, 2003 | 06:35 PM
civicsitek GanGsTa's Avatar
any compression calculator within .1 of a compression point is good by me
Old May 18, 2003 | 02:01 PM
RyanEJ8's Avatar
Default Re: Combustion Chambers (civicsitek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsitek &raquo;</TD></TR><TR><TD CLASS="quote">any compression calculator within .1 of a compression point is good by me </TD></TR></TABLE>
Agreed. Who knows how acurate Honda's claims are anyways.
Old May 19, 2003 | 07:09 AM
But it doesn't have the Z1 head on there though.
Old May 19, 2003 | 08:37 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89_CRX_HF &raquo;</TD></TR><TR><TD CLASS="quote">But it doesn't have the Z1 head on there though.</TD></TR></TABLE>
The Z1 Cylinder head specs can be found here.
http://pub143.ezboard.com/fhon...topic
You can then input the specs to the calculator.
Old May 19, 2003 | 01:55 PM
Thanks that helped alot!
What do you guys think?
11.1:1 w/hx rollers or 9.2:1 and boost 7lbs
Old May 20, 2003 | 11:34 AM
RyanEJ8's Avatar
boost
Old May 20, 2003 | 12:41 PM
Thanks I think I will and then maybe get an SI and put an hx head on it 14:1 cr. That would rule.
Old May 20, 2003 | 01:02 PM
RyanEJ8's Avatar
Don't forget high compression and boost requires ALOT of tuning. 14:1 would be too high for a daily driver on boost, you'd be asking for trouble. 10.5:1 or 11:1 is possible though.
Old May 20, 2003 | 01:08 PM
no, I mean keep the 9.2:1 boosted. Then get a whole other car with an a6 and put a z1 head on it. that woulb be n/a and the z6 will be boosted.
Old May 20, 2003 | 01:41 PM
RyanEJ8's Avatar
Oh I see.
Old May 20, 2003 | 06:34 PM
But I was also thinking about the Z1 head on my Z6 with boost using the hondata. At 11:1 how hard do you think it would be to get it in tune? I'm not sure exactly how hondata works.
Old May 20, 2003 | 08:02 PM
RyanEJ8's Avatar
You will need to tune on a dyno with wideband o2 sensor. You can use 11:1 C/R. Alot of people will say don't do it, but look at stock ITR's running 6 or 7 psi with no problems. They are 11:1. I wouldn't go very high on the boost with that kind of C/R though for a daily driver. Hondata with the boost option would be great for tuning this kind of setup, if you don't have any experience with Hondata yourself, I would just pay someone to tune it, that's what I'll be doing.
Old May 21, 2003 | 06:39 AM
Thanks I will look into that. That would be awesome.
yrpin5th
51
Dec 29, 2008 05:36 PM
Forrest Gump 9
Oct 31, 2006 05:18 PM
mer2ski
11
Jan 7, 2006 08:20 AM
b00stedbyFastrax
Jun 27, 2005 09:20 AM
Justin Olson
Feb 24, 2004 07:09 PM
