Combo of errors: F-CAN sys/comm, Yaw Sensor and Valve Relay
Old Aug 1, 2016 | 01:54 PM
jhawker23's Avatar
Default Combo of errors: F-CAN sys/comm, Yaw Sensor and Valve Relay
I have an '07 Ridgeline and I've had my VSA light and Triangle light on for quite some time. It came on following the removal of seats, carpet and console for running wiring from rear to front. I've done a lot of troubleshooting on the VSA module related to checking continuity, voltage and connection as well as the VSA Off switch and testing of harness. I was able to get the codes read today and I had quite a few before clearing. He cleared the codes and re-scanned. He re-scanned without driving the truck. I have the following codes...
91: F-CAN Comm
92: F-CAN Sys
25: Yaw Rate Sensor
54: Valve Relay
and
B1225: Interior Temp Sensor
I'v been leaning towards the yaw sensor since I had the console out and was working near it. Can a yaw sensor trigger the F-CAN comm and sys codes?
Also, the performance problems I've been having with very little power made sense with some of the codes he cleared, such as 73 - Eng Torque. Doesn't the truck need to be driven to trigger those codes after clearing?
I've been dealing with this for awhile and would appreciate any help. I don't mind getting a professional to fix the problem but I'd like to know as much ahead of time as possible.
Old Aug 1, 2016 | 06:32 PM
jhawker23's Avatar
Default Re: Combo of errors: F-CAN sys/comm, Yaw Sensor and Valve Relay
Problem solved. It was the yaw sensor. The harness wasn't secure to the sensor below the console.
97emsedan
Honda Civic (2006 - 2015)
Feb 2, 2018 05:31 PM
LoganSan
Nov 9, 2015 03:46 PM
SprayinCX
Aug 5, 2004 09:41 AM
jlv55
Mar 2, 2004 07:30 AM
