self-diagnostics ecu codes
0-------ecu
1-------oxygen sensor
3,5-----map
4--------crank sensor
6-------coolant temperature (tw sensor)
7-------throttle angle
8-------tdc position (tdc sensor)
9-------#1 cylinder position (cyl sensor)
10------intake ait temp. (ta sensor)
12------egr
13------atmospheric pressure (pa sensor)
14------electronic air control (eacv)
15------ignition output signal
16------fuel injector
17------veihcle speed sensor
19------a/t lock up control solenoid valve a/b
20------electric load dectector (eld)
21------spool solenoid valve
22------valve timing oil pressure switch
41------oxygen sensor heater
43------fuel supply system (except D15Z1 engine)
48------laf sensor (D15Z1 engine)
If codes other than those listed above are indicated, verify the code. If the code indicated is not listed above, replace the ECU.
all of this info was for a 92-95 civic out of my helms manual so all its is correct.
3,5-----map
12------egr
Re: self-diagnostics ecu codes (SprayinCX)
where exactly is the lil blue thing under the dash to make the light flash i know how to make it flash i juss cant find the blue connector
Location: Just Drank A 5th of VODKA Dare me to drive, Ca, u.s.
Re: self-diagnostics ecu codes (ludedudeh23)
if it has never been pulled out it is most likely tucked way up under the dash...you can find it on the passenger side of the car right of the glove box door
Re: self-diagnostics ecu codes (LoStMyBoOsT)
OK, I have a 96 Civic DX and I dont know how to get the engine light to blink to get the code. We did it a few years back, and cant remember what we did.
