Colder Spark Plugs
Old Apr 14, 2010 | 11:42 AM
Jimster480's Avatar
Default Colder Spark Plugs
I am currently running ZFR7F-11 plugs gapped to .025. This is on a boosted D16 making about 270WHP. I'm going to get tuned on 20+PSI soon, to make around 350WHP. Since they discontinued ZFR7F, I was told to go to BKR7E. But now that I'm going to be making more power, what plugs should I use? Since the 7 Step is the coldest step for the BKR series. I have seen racing plugs that have colder ranges but they are typically non-resistor. Is it ok to run non-resistor plugs? What are the alternatives?
Old Apr 14, 2010 | 05:03 PM
itslogz's Avatar
Default Re: Colder Spark Plugs
For that range from what I know BKR7E's are a good choice. I order mine from summitracing, since they stock them, shipping is quick as hell, and its only ike 5 bucks for shipping.
They are resistor type..
http://www.summitracing.com/parts/NGK-4644/
Old Apr 14, 2010 | 05:55 PM
Jimster480's Avatar
So I should be good with the BKR7E's on 350WHP?
Old Apr 14, 2010 | 06:23 PM
ralph11sec's Avatar
that depends. you should do plug read if you need colder plugs
Old Apr 14, 2010 | 06:51 PM
Jimster480's Avatar
what does that mean exactly?
Old Apr 15, 2010 | 08:25 AM
ralph11sec's Avatar
read on plug reading. or just ask ur tuner for it.
he'll know if u need colder plugs
Old Apr 15, 2010 | 09:13 AM
JDogg's Avatar
i'd run an 8 heat range, 7's will probably be ok but if you are too hot you'll melt a piston, if you are too cold you'll just foul the plug.
Old Apr 16, 2010 | 05:40 AM
Jimster480's Avatar
yea I was thinking about running 8 heat range, but on what plugs? Regular plugs dont go to heat range 8.
Old Apr 19, 2010 | 09:52 AM
welfarepc's Avatar
you can get R5671A-8's (non resistor plug) or you could go BKR8EIX iridiums.
i wouldnt use the projected spark plug you are using now. asking for hot spots....
i think BKR7E's would work great for your goals.
Old Apr 19, 2010 | 11:54 AM
Jimster480's Avatar
yea I am changing from the ZFR's. And i've heard that the iridiums do not work well in boosted setups because the finewire electrode gets burned up/off.
And can I run non resistor plugs in a street car?
zach1288
Jan 19, 2009 10:11 AM
Rhythmsnewsn
Apr 20, 2006 08:36 PM
hatchback
Jun 28, 2003 10:47 PM
ALLMOTOR18
Sep 10, 2002 03:05 PM
