Cold start
Old Mar 15, 2003 | 01:33 PM
ThrillaKilla's Avatar
Default Cold start
I was under the impression that import automobiles had a cold start feature that would boost your RPMs to around 2000 upon start up and gradually move down to standard idle once the car is warmed up, i have a JDM b16a in my car and am curious as to why my car dosn't do this.... a friend of mine has the same engine in his car and said he dosn't have that feature either... Is this a problem or normal??
TIA
one more thing, does anybody know of a website that has pictures of fully assembled intake manifolds so that i can match the vaccume line im missing up..
Old Mar 16, 2003 | 02:11 AM
Default Re: Cold start (ThrillaKilla)
anyone
Old Mar 17, 2003 | 07:30 AM
JimBlake's Avatar
I was under the impression that import automobiles had a cold start feature that would boost your RPMs...
I was under the impression that ALL cars have this feature in some way or other. Every car I've ever owned had it, but they were all a bit different. 2000rpm isn't always the magic number, either. Depends on the temperature.
'72 Datsun 510 - fast idle cam on the carburator
'74 BMW 2002tii - fast idle mechanism on the injection pump
'82 VW Rabbit - electrically heated auxiliary air valve on intake manifold
'86 Jetta - ECU controlled auxiliary air valve on intake manifold
'89 Saab 900 - ECU controlled AIC valve across throttle body
'95 GS-R & '98 Accord - air bypass valves on manifold
'01 Saab - ECU tells the drive-by-wire throttle to open just a bit
Old Mar 17, 2003 | 07:36 AM
liquid51's Avatar
Default Re: Cold start (JimBlake)
in my carbed '84 prelude you had to pump the gas pedal once before startup.
Sorry though, I know that doesn't really help.
Old Mar 17, 2003 | 07:58 AM
speedymon's Avatar
Default Re: Cold start (liquid51)
When you start it up cold what does it rev to?
Old Mar 17, 2003 | 10:55 AM
Aron Parsons's Avatar
Default Re: Cold start (speedymon)
Most cars idle high until they warm up. If you're referring to the 'Fast Idle Solenoid', some vehicles don't have it. 90-91 Civic/CRX Si's had them for sure, but only kick in when temperature is below freezing.
Old Mar 17, 2003 | 05:54 PM
thats the problem, when i start it up cold it dosn't rev to anything but a boggy 800-1k/rpm... i think my injectors are getting bad too i tried starting it today and it would just crank over and over but eventually squeezed out a luggy bogged down start...
Old Mar 20, 2003 | 12:34 PM
lyzer227
15
Feb 17, 2009 12:42 PM
lyzer227
Feb 7, 2009 12:02 PM
ATS*Mark
Sep 28, 2005 02:37 PM
delguiner
Sep 25, 2004 01:45 PM
