Cold Start..
Old Mar 20, 2002 | 07:34 PM
UNVMYR's Avatar
Default Cold Start..
My car idels very low in the morning or on any cold start..most cars I know will idle at like 2500 or so till it warms up...my car idls at like 200 for a cold start warm up.
I have a jdm R with p73
Old Mar 21, 2002 | 10:35 AM
Perfectionist's Avatar
Default Re: Cold Start.. (UNVMYR)
Normal cold idle should be around 1800rpm and slowly drop to the warm idle spec for your car. In your post, do you really mean 200 or 2000? If it's really 200, (the stock tach doesn't really indicate much below 500), I would suspect the Fast Idle Valve isn't working or not getting the signal to open.
Old Mar 21, 2002 | 10:54 AM
Kamin's Avatar
Default Re: Cold Start.. (Perfectionist)
yea if it really is at 200 check your idle air control valve
its a b18c5? definatley check the iacv and vacume lines.
[Modified by KAMiN, 11:55 AM 3/21/2002]
Old Mar 21, 2002 | 09:03 PM
UNVMYR's Avatar
Default Re: Cold Start.. (KAMiN)
Yeah well mines still in the Intake instead of the manafold...when they did the swap
they left it in there and said it should be fine...Also the vacume line coming off the throttal body just dangles with a screw in the end of it i guess to simulate full trottal..or some ****...
Old Mar 21, 2002 | 10:04 PM
Smashback's Avatar
That's what ghetto riggers do to plug a vacuum nipple instead of putting a rubber plug on there that costs .02 cents.
Old Mar 21, 2002 | 11:51 PM
UNVMYR's Avatar
Default Re: Cold Start.. (mplex2000)
the swap is some of the best ive seen its not rigged by far...it was done for a reason and that reason is beyond me...
Ryan Detwiler
Feb 3, 2013 03:44 PM
TearSDMF89dx
Jan 3, 2012 04:31 AM
crashtest Sonny
13
Mar 4, 2003 03:49 PM
s2k
Feb 25, 2003 06:50 PM
wickedxboi
Nov 9, 2002 12:39 PM
