cold spark plug, cold 10
Old Sep 3, 2006 | 09:26 AM
yeungkaho's Avatar
Default cold spark plug, cold 10 - **RACING**
i am currently in the market looking for cold ten ngk spark plug...
my frd gave me some part number that he used on his lotus, so i order some in, but it didnt fit, B10EV.
i couldnt find other cold 10 that fits for sure
does anyone know any part number that fits, i need to buy 24 spark plugs, 12 for spare
for my s2000, ITR, and miata
if possible, i prefer 13 heat range
my car knocks crazy running on 94 octane, i had to retard a lot of timing...
Modified by yeungkaho at 5:30 AM 9/4/2006
Old Sep 3, 2006 | 01:33 PM
onepoint6i's Avatar
Default Re: cold spark plug, cold 10 (yeungkaho)
damn. is it a tuned motor?
Old Sep 3, 2006 | 08:32 PM
yeungkaho's Avatar
yes....high comp.i use to run 104 octane, it was a lot better, but now only 94.
Old Sep 3, 2006 | 08:44 PM
locash's Avatar
Default Re: cold spark plug, cold 10 - **RACING** (yeungkaho)
I hate to be the bearer of bad news, but an NGK heat range 10 spark plug is WAY TOO cold for your S2000 or ITR, unless you're making a shitload of boosted power (ie: over 700?). If the car(s) are detonating, you probably just have too much timing in them.
Old Sep 3, 2006 | 08:52 PM
yeungkaho's Avatar
i only use heat 10 during racing. what my frd do is he run his car hot. then change to heat 10, so that he can start and race. btw, his lotus only has 110 horsepower, and comp is less than mine. it just gets rough idle, no stalling. and hard start.
Old Sep 3, 2006 | 09:11 PM
PinkMaggit's Avatar
Default Re: (yeungkaho)
call Tom from camp1320 if anyone gots it, it will be TOM.
Old Sep 4, 2006 | 08:59 AM
yeungkaho's Avatar
is that his username camp1320
Old Sep 4, 2006 | 09:03 AM
yeungkaho's Avatar
nvm, found their website, any other place that sellls cold 10 spark plugs, online shops?...
btw....how much do they cost.,
the ones my frd got for his lotus costed $8.5 canadian each.
Old Sep 4, 2006 | 01:15 PM
DonF's Avatar
I get mine from sparkplugs.com. If I can find them so can you. Plugs will not cure your overheating or detonation, just a band-aid. Champion N57's would be better but cost more, so that is probably not an option.
Old Sep 4, 2006 | 05:20 PM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeungkaho &raquo;</TD></TR><TR><TD CLASS="quote">i only use heat 10 during racing. what my frd do is he run his car hot. then change to heat 10, so that he can start and race. btw, his lotus only has 110 horsepower, and comp is less than mine. it just gets rough idle, no stalling. and hard start.</TD></TR></TABLE>
Yeah what he said! And why on earth would you run heat range 13...lol? That's too funny.
Here are some NGK part numbers for 9s and 10s that I run:
Stock No. 5238
Part No. R5671A-9 (Heat range 9)
Stock No. 5820
Part No. R5671A-10 (Heat range 10)
Old Sep 4, 2006 | 07:52 PM
aj99si's Avatar
Default Re: (Blown90hatcH)
the 5238 is what a lot of boosted hondas run. they are great plugs for cars in the 400 hp range.
Old Sep 5, 2006 | 07:58 AM
ykracing's Avatar
Default Re: (aj99si)
I always ran these.. (as said above)
Stock No. 5820
Old Sep 5, 2006 | 08:02 AM
yeungkaho's Avatar
thanks
Old Sep 5, 2006 | 01:05 PM
d16dcoe45's Avatar
Jegs and Spakplugs.com both have NGK r5671a-9 and r5671a-10. I am running a Champion C61cx-which is very similar to an ngkr5671a-8--except the Champion has a cut-back ground strap. I have found the Champions do not foul as easily. You can try a c59cx or c57cx Champion--I prefer them over the NGK r5671a series. Also Sparkplugs.com and they were like $3.69 each. Champion heat ranges go in multiples of 2. And the larger the number the hotter the plug where with NGKs the larger the number the colder the plug.
Old Sep 5, 2006 | 02:40 PM
DonF's Avatar
Default Re: (d16dcoe45)
The CX is a very good plug. The NGK is cheaper and almost as good.
Old Sep 6, 2006 | 11:05 AM
yeungkaho's Avatar
i just went order plugs at my local store...
$3.5 cad a piece....ordered 32, some for my frds....
i also got a set of cold 9 that i am now running on my car daily....it seems ok....to only things is....it takes longer for cold start....but other than that....it runs great....
Old Sep 6, 2006 | 02:13 PM
d16dcoe45's Avatar
I think at sparkplugs.com the NGKs (r5671a-7,8,9 or 10) are a bit cheaper than the Champion CXs--at Jegs I think they are the same price. I don't know if it has to do with the cut-back ground on the Cx--but I would really recommend them for a high-compression N/A application over the 5671a. The NGKs really foul quite quickly in my motor. The Champions don't--I have a set of 63cx on order--supposed to be closer to an NGK r5671a-7.
Old Sep 8, 2006 | 08:59 PM
yeungkaho's Avatar
ok update....cold 9 seems to runs as great as cold 7 @ low rpm....
but during high rpm, it starts to become noticibly better....
i just got 36 cold 10s....hehe....
i dont care if it fouls easy, i'll just put on a new one...
hope the 36 plugs will last the next season
DDTECH
27
Sep 29, 2009 11:01 PM
WanderingSamurai830
Apr 14, 2007 09:19 PM
Quitripin
16
Aug 18, 2004 09:20 PM
toooslow
May 14, 2003 11:37 AM
Adam.
Sep 14, 2002 02:00 PM
