Cold or Hot Spark Plugs
I know that cold spark plugs are to prevent the plug from igniting the mixture too soon. And at Higher RPM you would need a colder spark plug because the plug is going to be running more often and therefore hotter.
My question is, Are the any repercussions to using a cold spark plug when it's not necessarily needed?
Re: Cold or Hot Spark Plugs (civicgirl114)
I have never heard of this cold spark plug...hot spark plug??
Re: Cold or Hot Spark Plugs (DRAG lll INTEGRA)
colder plugs are for forced induciton use.
[Modified by DarkKnight[DMD], 10:16 AM 9/12/2002]
Re: Cold or Hot Spark Plugs (DarkKnight[DMD])
not really, it's just a little harder to start the car in the morning. I'm using the blitz iridium 7's and I actually get a little better gas milage with the 7's. good luck
Re: Cold or Hot Spark Plugs (EK Spec R)
you are talking about different heat ranges as per spec'ed on the plugs
for example Denso IK16 or IK20 is equal to a heat range of 5 or 6 respectively...
The reason for this is that the proper range allows for the plug to heat up to a temp that will keep the electrode and ground clean without detonation...With Cams and compression, boost or NOS, you go one to two steps colder as it is an increase of cylinder pressure...
i think stock GSR is IK16 or #5
add boost or anything go up one to two ranges
I have to find the post on this as it has more details
Re: Cold or Hot Spark Plugs (555R)
i didnt replace my stock plugs when i got the blower install d ..as a result the plugs foul d withing minutes..i would think something would happen to a colder plug if it wasnt necessary
RACEPAK
09-21-2005 04:08 AM
