Cold lower radiator hose?
Old Dec 3, 2004 | 08:57 PM
TypeR0186's Avatar
Default Cold lower radiator hose?
Just did a swap. k20a. The tempeture goes up quickly. The top hose is hot but the lower hose is cold. I tried to bleed the radiator by opening the cap and turn the hot air on while car is on. One thing i notice is that the coolant doesn't even circulate at all. It just sit there. Plz help...
Old Dec 3, 2004 | 09:07 PM
burnout289's Avatar
Default Re: Cold lower radiator hose? (TypeR0186)
did you put in a new thermostat? it may not be opening. even if the bottom outlet was plugged you should have coolant spilling all over the place if the thermostat was opening. if you don't see water moving once the car is at normal operating temps, replace the thermostat. best part about it is that they are cheap! if you still have problems at that point, you could have a clogged radiator, though that isn't too likely [usually there will be at least SOME flow].
Old Dec 3, 2004 | 09:14 PM
TypeR0186's Avatar
yeah i'll try the thermostat. yeah the coolant doesn't flow at all in any temp. It's a new radiator too.
Old Dec 3, 2004 | 09:16 PM
JBBNJ609's Avatar
how high is the rad?? if its nto high enough it may not flow right, that was my problem. . also what kinda rad is it ?? did you bleed the sys right ??
crazyhouse2011
10
Feb 11, 2014 11:02 AM
IntegraR0064
Jan 27, 2009 10:41 AM
aj_scribble
Mar 20, 2008 10:28 AM
fanta!
Aug 14, 2005 02:14 PM
TypeR0186
Dec 4, 2004 01:40 PM
