cold compression test results
I had a compression test done on my car 94 JDM H22a swap when it was cold. Basically it sat over night until about 4 pm. Then did the test.
I was wondering would the results be that far off depending on cold or normal operating temps?
Cause when it was done the guy said it was 250 across the board, but then I get on here today and read some old posts and it looks to be a bit high. I am wondering if the test was done wrong or if the cold motor has a huge factor on correct numbers?
thanks
mike
thanks
mike
Yeah I am gonna have to buy a compression tester and do it myself. I thought it was alittle weird. So I should be doing this at normal operating temp?
thanks
thanks
ricanxplaya
27
Feb 9, 2012 03:17 PM
rhemu1
Jul 20, 2004 11:21 PM
