Code with chip P28 ecu ?
Old Sep 10, 2002 | 04:24 PM
jack25racing's Avatar
Default Code with chip P28 ecu ?
What is this code: one long, one long and one short ? Do it's 21, I need the confirmation, do it's the code for the vtec solenoid?
If I want control the Vtec just with my VAFC I also need to plug the solenoid to the p28 but I don't understand why I will appreciate some information ?
Thanks !!
Old Sep 10, 2002 | 06:33 PM
HOND PWR's Avatar
Default Re: Code with chip P28 ecu ? (jack25racing)
Code 21 is VTEC Solenoid Valve (defective circuit or unplugged/ defective solenoid valve).
I have a chipped p28 with a Fields Vtec controller wired to the ECU. Not sure why you have to though. Maybe its tied in with somthing else in the ECU?
Old Sep 11, 2002 | 05:16 AM
Default Re: Code with chip P28 ecu ? (HOND PWR)
I have connect the VTEC Solenoid Valve and now it's the code 22, this is the code for the vtec pressure switch, but I don't have this ?%$$%@# of switch (JDM b16a1 head). I was thinking the chip P28 don't check this sensor ?
Old Sep 11, 2002 | 05:35 AM
CHEETAH's Avatar
the 88-91 pr3 dohc vtec ecus dont check for the oil pressure, the P28 and other 92+ vtec ecu's does ... need to trick it. Also, if you install an SFC vtec controller or Apex VAFC it will give the euc the signal for you.
Greg
Old Sep 11, 2002 | 05:47 AM
Default Re: Code with chip P28 ecu ? (CHEETAH)
I am not sure to understand, can I simulate the vtec pressure switch with my VAFC or do I need to install this sensor ? I am I little confused
Old Sep 11, 2002 | 06:34 AM
CHEETAH's Avatar
the vafc gives its own simulated signal to the ecu, and does not require input for the pressure sensor.
Greg
Old Sep 11, 2002 | 06:41 AM
If I want to install the pressure switch can I plug it at the place of the 10mm bolt just under the solenoid. But I already waiting to know how can I bypass this switch with the VAFC ?
Old Sep 11, 2002 | 06:49 AM
Thanks, I will try this !!!
Old Sep 11, 2002 | 08:16 AM
Everythings works great and it's very powerfull, thanks of your help !!!
pureclass69
Mar 14, 2011 03:05 PM
SiR Inspired ED7
Nov 2, 2008 05:49 PM
LShatchie
19
Oct 3, 2006 07:04 PM
the.hamburglar
Mar 16, 2006 05:55 AM
Houston Hatchback
Aug 24, 2002 06:03 PM
