CODE 54... car isn't drivable.. what to do... plz help~
Old Oct 9, 2005 | 11:25 PM
PaChiLa Leader's Avatar
Default CODE 54... car isn't drivable.. what to do... plz help~
Code 54 is for CKF sensor which tells the engine where Cylinder one is and when to fire right?
well my car starts fine but whenever i throttle more than half car just went dead..
checked the CEL and shows CODE 54
help me plz.. thank you
I think it might have something to do with the CKFM ground.. where do i ground it?
Old Oct 9, 2005 | 11:39 PM
JDMOrangeFever's Avatar
Default Re: CODE 54... car isn't drivable.. what to do... plz help~ (PaChiLa Leader)
What year is car... motor etc.. You have a distributor on the vehicle? Could be distributor messin up.. ( Cause CYP, CKF, and TDC is in distributor.. hell just try putting a buddys dizzy on.. thats one easy way to do it...
http://www.honda.co.uk/owner/C...4.pdf
Old Oct 10, 2005 | 12:28 AM
Default Re: CODE 54... car isn't drivable.. what to do... plz help~ (JDMOrangeFever)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMOrangeFever &raquo;</TD></TR><TR><TD CLASS="quote">What year is car... motor etc.. You have a distributor on the vehicle? Could be distributor messin up.. ( Cause CYP, CKF, and TDC is in distributor.. hell just try putting a buddys dizzy on.. thats one easy way to do it...
http://www.honda.co.uk/owner/C...4.pdf</TD></TR></TABLE>
I have a 2000 ITR with 00 LS cabine harness and 99 ITR motor
Old Oct 10, 2005 | 12:34 AM
Ok, yeah check the distributor.. thats where i would check first
Old Oct 10, 2005 | 08:44 AM
JimBlake's Avatar
CKP, CYP, & TDC sensors are in the distributor. But CKF is crankshaft FLUCTUATION sensor, it's mounted on the oil pump, where it picks up teeth on the crankshaft timing sprocket.
The CKF sensor doesn't control spark timing, the ECU uses it to detect misfiring. So I don't think a bad CKF sensor would cause the stalling you describe.
Old Oct 10, 2005 | 09:23 AM
EE_Chris's Avatar
Default Re: CODE 54... car isn't drivable.. what to do... plz help~ (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">So I don't think a bad CKF sensor would cause the stalling you describe.</TD></TR></TABLE>
Me neither.
Old Oct 10, 2005 | 09:38 AM
really? but my car isn't drivable.. whenever i shift in gear.. step on the throttle and the car just die.. what's wrong with it.. seems like there isnt enough gas going to the engine... i checked the CEL and it only tells me one code 54...
i really have no idea what to do right now.. i can't even drive the car to the shop .... someone plz help me out~
SkIp_Civic_Ek6
Nov 27, 2019 10:08 AM
Fat Chick Magnet
Jul 30, 2006 09:06 AM
psycho.chicken
Jul 21, 2006 09:34 AM
d0nkeyxPunch
Dec 7, 2004 06:17 AM
Reddog
Aug 28, 2002 01:24 PM
