Code 43 fuel Supply resolved
Old Dec 30, 2003 | 06:29 AM
maddog20's Avatar
Default Code 43 fuel Supply resolved
I noticed I have been getting a cel 43 on my P28 ECU. After replacing my fuel filter and Fuel pump per Helms Manual. Still had the same code.
This code is very broad and can be numerous things. I found after testing my O2 when the eng was cold once warm it took awhile to switch to closed-loop operation. I found out that if you get improper O2 readings you're ecu's short term and long term fuel term will go to 20% which will throw throw the code. New O2 problem solved! Just some info for those who have has this problem.
PhilStubbs
Jan 22, 2005 11:20 AM
DC2EGHB
13
Mar 18, 2004 05:44 AM
Ratedrr
Jul 29, 2003 02:40 PM
importimage
Jun 30, 2003 04:27 PM
OBDI JEDI
May 7, 2003 05:06 PM
