code 20?
whats up guys. dumb question here, but what on earth is this code refering to? electric load detector is what the code states, but what dose that mean? the vehicle is drawing too much amperage? if someone could give me a little overview of what this code means, and what could be a cause of failure to throw this code i would greatly apreciate it. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NathanielH »</TD></TR><TR><TD CLASS="quote">whats up guys. dumb question here, but what on earth is this code refering to? electric load detector is what the code states, but what dose that mean? the vehicle is drawing too much amperage? if someone could give me a little overview of what this code means, and what could be a cause of failure to throw this code i would greatly apreciate it. thanks
^^ you have a short somewhere...check fuses, or start testing wires (ugh)
good luck and hope you can resolve this swiftly
</TD></TR></TABLE>^^ you have a short somewhere...check fuses, or start testing wires (ugh)
thanks for the goodluck wishes man. i hope i figure it out too, im an just cofused as to what senses the excessive load, the "detector"? and could it just be my alternator output is low? i have no idea where to start here
The ELD is a current-measuring device built into the under-hood fusebox.
First, look for broken or loose wires in that circuit. After you rule that out, then you have to get a new fusebox.
