Code 12 - EGR system with H22A into civic
Old Sep 8, 2002 | 10:49 AM
poison's Avatar
Default Code 12 - EGR system with H22A into civic
hey, I just recently put an jdm H22A into a 93 civic coupe ex (ej1) and get check engine light,
I pulled the code and got code 12 which is the EGR system. I thought that JDM h22 p13's bypass this?? anyway of bypassing this code
I also have a very wavy idle
please help thanks
Old Sep 8, 2002 | 11:47 AM
goforbroke's Avatar
MEAT PATTY
Default Re: Code 12 - EGR system with H22A into civic (poison)
I have the same problem with my b16a still trying to figure it out. I have the wavy idle to. It only comes on sometimes but check engine light comes on it does a little funky idle. I swear i smell some gases in the car. But b16a don't have EGR valves so i'm clueless a little.
Old Sep 8, 2002 | 12:27 PM
poison's Avatar
found the problem with the wavy idle, it's the throttle body gasket.
as for EGR, i'll run the check engine light till i get it chipped i guess
unless there is a way of bypassing
Old Sep 8, 2002 | 12:33 PM
Mikey3000's Avatar
that light isn't gonna do anything to hurt performance so u really don't have to get it removed from the ecu. btw: yes jdm p13 does look for egr, mine does and i drive around with the light too.
Old Sep 8, 2002 | 02:59 PM
Timmayeg's Avatar
New User
Default Re: Code 12 - EGR system with H22A into civic (Salvatore Leone)
how do you hook up the EGR?
Old Sep 8, 2002 | 05:35 PM
Mikey3000's Avatar
Default Re: Code 12 - EGR system with H22A into civic (H22a-CX)
plug it in....lol. if it's on your IM already all you have to do is plug it in.
Old Sep 8, 2002 | 11:18 PM
poison's Avatar
I'm not gonna hook up the EGR and for some reason it's not throwing the code anymore. Very strange.
Although I do have a slightly bouncy idle when i start it up, then when i go, it launches very nicely but kinda 'bogs', as in needing to give it more gas then i should and still accelerates slow.
I am hoping that hooking the exhaust will fix the problem, we'll have to see.
Old Sep 9, 2002 | 07:19 AM
jeff652's Avatar
The code is still there, it's just not lighting up the CEL any more. Pull the code again, you'll see it's still there.
You should hook the EGR system up, so the computer can run in closed loop mode.
Old Sep 9, 2002 | 04:05 PM
poison's Avatar
Default Re: Code 12 - EGR system with H22A into civic (jeff652)
ya I'm tempted to hook it up.
I also have a wavy idle and kinda idles like ****.
I have the idle screw in the TB all the way out to keep the motor alive.
plus the AIB isn't flexing at all
running in limp mode have anythign to do with that?
Old Dec 22, 2002 | 08:41 PM
cpforyou's Avatar
Just use a P72 ECU.
Check out the results:
http://www.importreview.com/reviews/PreludeECUtest.html
[Modified by cpforyou, 5:52 AM 12/23/2002]
jeff gonzalez
10
Jun 27, 2019 10:16 AM
NeedmoPowr
Oct 28, 2014 06:15 PM
tsim
Jul 4, 2009 08:35 AM
Problemo
Mar 18, 2006 10:26 AM
bags
Sep 13, 2004 09:10 PM
