check engine light code
Old Sep 7, 2004 | 03:13 PM
bags's Avatar
Default check engine light code
my check engine light came on today after having this very weird idle problem with my car which is a 98 accord
the code came back p0505-idle system malfunction.
anyone have any idea what this means and does it require immediate attention?
Old Sep 7, 2004 | 03:15 PM
TxTuner
Guest
Posts: n/a
Default Re: check engine light code (bags)
Probably (just guessing) just need to have your idle reset. What does it idle at right now?
Old Sep 7, 2004 | 03:16 PM
bill-71SS's Avatar
most likely problem will be the idle air control valve,is it going from like 700-2000 rpm's. you can also try cleaning the throttle plate
Old Sep 12, 2004 | 06:53 AM
ironryder's Avatar
how did you get the code??i got a 98 civic but i don't have a scan tool is it possible to get the code??
Old Sep 12, 2004 | 08:20 AM
WillsH22Accord's Avatar
you could always pull the iac off and clean it, they tend to cause shitty idle when clogged
Old Sep 13, 2004 | 09:10 PM
hondaacuratech's Avatar
if you have 98 accord v6 and it's throwing that code, replace IAC. It is common problem, but before replace IAC clean the throttle plate.
Rekkerslude
Engine Management and Tuning
Sep 21, 2017 10:33 AM
cartune network
Apr 1, 2016 01:02 AM
jewpont
13
Dec 18, 2007 07:54 AM
88hondacrx
Oct 28, 2006 12:49 PM
god.loves.ugly
Jul 27, 2005 07:32 PM
